New Topic New Reply
Author: Subject: GRP Panels: Glue or Screw ?
Toprivetguns
posted on 12/6/12 at 08:55 PM Reply With Quote
Evening all,
Im just about to fit my side panels. Any suggestions on which you would prefer ?
At the moment its either sikaflex to bond the panels or riv-nuts with C/S allen key bolts for that neat flush look.
[Edited on 12/6/12 by Toprivetguns]
Only drive as fast as your angel can fly... !
Davegtst
posted on 12/6/12 at 09:02 PM Reply With Quote
Mine are bonded on. I used a few ratchet straps and bungees around the chasis to hold them in place until the glue went off.
Toprivetguns
posted on 12/6/12 at 09:04 PM Reply With Quote
Thanks Dave,
Im more keen on that route as well. Just curious about other peoples opinions. Thanks !
aka_shortie
posted on 12/6/12 at 10:46 PM Reply With Quote
If it was me i would be doing both, bonded and riveted
[Edited on 13/6/12 by aka_shortie]
renetom
posted on 13/6/12 at 07:27 AM Reply With Quote
screw
Hi
definitely screw
We used stainless steel flange head self tappers No6
worked fine and glad we did after an accident when we had to replace a side panel.
Can you imagine the amount of work and mess trying to remove a bonded one.
Good luck
René
renetom
posted on 13/6/12 at 07:39 AM Reply With Quote
Panels
Hi Again
Further to my last post
As the panels rarely fit perfectly on the underside we cut strips of black plastic skirting (used on partitioning)
to pack out the gaps with longer screws.
posted on 13/6/12 at 11:55 AM Reply With Quote
We too bonded ours to the chassis. We clamped the panels using lengths of wood, both vertically and horizontally, to ensure the panel was flat. The only downside to this method is that the panels will be destroyed if they ever need to be removed to change the colour of the vehicle, or if the side panel is accidentally damaged and needed to be replaced.
I guess it depends what you intend to use your vehicle for and whether you want the structural rigidity offered by rivets, or resonance reduction offered by bonding...... or perhaps both.
Phil
Toprivetguns
posted on 13/6/12 at 06:52 PM Reply With Quote
Thanks Gents, again your honestly is appreciated.
GOJO
posted on 15/6/12 at 06:13 PM Reply With Quote
I used counter sunk stainless screws on the top edge and large flange rivets on floor edge and put tiger seal on the chassis trellis where it will touch 1 to keep the panel in shape and 2 to stop any vibrations.
Pezza
posted on 15/6/12 at 08:56 PM Reply With Quote
Like my dad said above, we've secured our side panels with screws. no hint of vibration but easy to remove in the event of a booboo.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
New Topic New Reply
