Author: Subject: aulternator
leeswesty
posted on 15/6/12 at 05:27 PM Reply With Quote
aulternator
Hi all i need help with alternator i have followed this pic but the light stays on it will not go out any help will be much appreciated
Live life to the max
posted on 15/6/12 at 05:34 PM Reply With Quote
You are using a bulb warning light not an LED ?
leeswesty
posted on 15/6/12 at 05:39 PM Reply With Quote
Yes the one like a spade end i am stump t i have only got to sort this and rev counter and all elec sorted
zetechamo
posted on 15/6/12 at 06:11 PM Reply With Quote
The wiring is correct, the warning light goes out when you get a balanced voltage across it Therefore if the bulb does not go out check to see what voltage is coming out of the alternator.
leeswesty
posted on 15/6/12 at 06:20 PM Reply With Quote
I am getting 13.9 volts its a Daihatsu Charade alt on pinto eng
scudderfish
posted on 15/6/12 at 06:27 PM Reply With Quote
Blip the engine and give it a few revs. Some alternators need a bit of a kick to get them going.
leeswesty
posted on 15/6/12 at 06:33 PM Reply With Quote
will give it a try thanks for all your help what is the best light to get as alt light
gremlin1234
posted on 15/6/12 at 06:43 PM Reply With Quote
alternators use the warning light in a peculiar way, you will require a bulb to the spec of the original car (the Daihatsu Charade) warning light.
leeswesty
posted on 15/6/12 at 06:53 PM Reply With Quote
Will have a look for one on ebay thanks
