Author: Subject: Eccentric pipe reducer
probablyleon
posted on 21/6/12 at 06:01 PM Reply With Quote
I'm looking for an eccentric pipe reducer 100mm to 75mm to reduce the outlet from a NACA duct down to the inlet I now have on my airbox. Any ideas? An aluminium or rubber Samco type thing is probably what I'm after but totally open to suggestion.
big-vee-twin
posted on 21/6/12 at 06:25 PM Reply With Quote
How about this 102/76mm SILICONE HOSE STRAIGHT REDUCER.Siliconhoses.com.Intercooler | eBay
http://www.triangleltd.com
posted on 21/6/12 at 06:55 PM Reply With Quote
That's a concentric reducer. An eccentric reducer has wall of the the smaller pipe inline with the wall of the larger pipe at one point. i.e. the smaller pipe is offset.
Don't know where one could find such a thing however.
[Edited on 21/6/12 by MikeRJ]
owelly
posted on 21/6/12 at 07:10 PM Reply With Quote
http://www.pinchinpipesandfittings.co.uk/BWF_Eccentric_Reducer.html
http://www.ppcmag.co.uk
Fred W B
posted on 21/6/12 at 07:11 PM Reply With Quote
If you can work in stainless try finding dairy equipment suppliers, they will have all sorts of nice pipe bits in thin wall stainless, most likely including offset reducers.
Fred W B
