gunman
| posted on 29/6/12 at 12:59 PM |
Sierra Diff, shafts and brakes
standard 7" sierra Diff (push in shafts), complete with entire rear baem\wishbones\shafts\Hubs (for drums) and drum brake setup. Happy to
split for any bits you want.
Looking £50 for the diff and £25 for the shafts. Let me know if you want any of the other bits and I will get a price.
Also have a pair or front sierra calipers, these are in great order and look to have been a recon (or new) pair and the car covered less than 6,000
miles with them. They are complete with carriers and pads (used) and good used discs. These are the 240mm disc setup. Looking £50 for them.
Collection from Newtownards (N. Ireland) or will arrange shipping at cost.
JeffJeffers
| posted on 29/6/12 at 01:24 PM |
Any chance the diff is limited slip?
gunman
| posted on 29/6/12 at 01:28 PM |
Absolutely none. I took it out to fit one. Very rare to find an LSD with push in shafts.
Not Anumber
| posted on 29/6/12 at 02:02 PM |
Is it the general rule that drum brakes and push in shafts go together or did they also do some push in shafts with disks
gunman
| posted on 29/6/12 at 02:14 PM |
I'm not 100% sure but if they did I haven't come across them yet, I do know that the Hubs are very different but that's due to the
different shafts.
As a rule of thumb I'd say push in shafts mean drums and non lsd
whitestu
| posted on 29/6/12 at 02:15 PM |
It is. Generally the disk braked cars had bolt on shafts, but you can never be 100%.
gunman
| posted on 29/6/12 at 02:17 PM |
you can use cut down bolt on shaft hubs so you can have a bolt on shaft and drum brakes, problem with the other way round is there's nowhere to
bold your calipers on.
Not Anumber
| posted on 29/6/12 at 02:37 PM |
Thanks. Ive learned something today as I'd been assuming the diffs were all physically the same and some just had short extensions pushed in
which the bolt on shafts then attached to.
Apologies for high jacking the thread .
loggyboy
| posted on 29/6/12 at 02:43 PM |
That is pretty much the case, the extensions (AKA inner stub shafts/stub flanges) that are used on bolt on shafts dont just push though, they are held
in with clips from the inside.
Mistral Motorsport
loggyboy
| posted on 29/6/12 at 02:48 PM |
OP - what size drums are they?
Mistral Motorsport
gunman
| posted on 29/6/12 at 02:59 PM |
not sure, I'll check when I get home tonight.
Chippy
| posted on 29/6/12 at 03:51 PM |
You can get conversion plates that fit on the drum brake hubs, so that you can fit disc's. This is how mine is set up. MNR's do the
conversion plates. HTH Ray
Not Anumber
| posted on 29/6/12 at 04:15 PM |
Is that route cost effective compared to sourcing a pair of bolt on shafts and matching diff ? Are the bolt on parts difficult to get hold of ?
gunman
| posted on 29/6/12 at 06:08 PM |
Drums have 229.4mm max on them, hope it helps.
gunman
| posted on 29/6/12 at 06:39 PM |
loggyboy
| posted on 30/6/12 at 01:28 PM |
No generally the other way round, I can't get a CV rebuild kit for my push in shafts so im after a strange route of bolt on shafts with drum
brakes...
Mistral Motorsport
gunman
| posted on 30/6/12 at 02:07 PM |
That's easy enough done by cutting the lugs off the hub carriers for the calipers and using them with the drums.
