Author: Subject: Wills
BobM
posted on 4/7/12 at 01:16 PM Reply With Quote
Wills
Any locost advice about sorting out a will.
I really ought to sort it out seeing as I spend a lot of time on track at the same time as Austen
Not very Locost but very BEC
Stott
posted on 4/7/12 at 01:20 PM Reply With Quote
Just sign it all over to me, I'm not far away, I can collect.
Dick Axtell
posted on 4/7/12 at 01:50 PM Reply With Quote
Hi BobM,
Have only recently done new wills. Advice comes in 2 basic versions.
Version 1:
If its to be a simple will, leaving everything to your wife/husband, or if he/she dies beforehand, to your children .........
then a simple will, 1 sheet of A4 can suffice. I can provide a suitable format.
Version 2:
If its not simple, for whatever reason, e.g. you are an unmarried couple, or you have children from a previous relationship, or if you have any reason to be uncertain about the construction of a will ......................
See a good solicitor. This is essential, because such a solicitor will have much greater knowledge of all the legal ramifications relating to those examples I referred to above.
For either version, you should also consider the question of property ownership. Is your house owned jointly, or in only 1 name? You should check out the possibility of changing from "Joint Tenancy" to "Tenants in Common". This last refers to the situation where each party agrees to ownership of shares in a given property.
Good luck.
r1_pete
posted on 4/7/12 at 02:04 PM Reply With Quote
Just don't go to one of these 'We'll help write and manage your will for free', because in the small print they name themselves as executor, and charge a whopping %age when the time comes....
BobM
posted on 4/7/12 at 02:29 PM Reply With Quote
Originally posted by Dick Axtell
Version 1:
Yes, the above. Married, joint owners of house etc. no real complications. I suspect a simple template based jobbie would be adequate.
wicket
posted on 4/7/12 at 02:39 PM Reply With Quote
My wife and I had ours done for nothing by a solicitor in return for a donation in our wills to a charity, in our case Cancer Research UK. They don't seem to do it all the year round but we get solicitor adverts in the local press when they are offering this service. The charity pays for the will(s) being prepared.
[Edited on 4/7/12 by wicket]
Mr Whippy
posted on 4/7/12 at 02:49 PM Reply With Quote
ditto the same for us but even though we are married and no kids I found there were way more things to take into account than I expected, I thought I was just going to leave everything to the missus but that's just the beginning
