Author: Subject: best sierra model?
Will_82
posted on 7/9/04 at 11:53 AM Reply With Quote
best sierra model?
Right ive decided sierra is the way to go for me, but what model is the most suitable??
ive seen a 2.0i but would injection complicate things, because im not totally confident of deviating from the book and sierra alltogether is quite daunting.
Ive looked through past posts and learned alot but this im unsure of.
any advice is much appreciated, Cheers Will
posted on 7/9/04 at 11:58 AM Reply With Quote
Hi Will,
General opinion seems to be that the early 2.0L SOHC (Pinto) Sierra is the easiest model to use. It has the simplest ignition system for a start and will require the least modification of parts. The 2.0i for example will probably require you to modify the injection plenum to fit under the bonnet or a change to carbs.
HTH
Nick
stephen_gusterson
posted on 7/9/04 at 12:26 PM Reply With Quote
be aware that anythign 1989 or so on wont be a pinto - it will be a dohc
atb
steve
ned
posted on 7/9/04 at 12:43 PM Reply With Quote
as said an early pinto car. this will normally have a type 9 gearbox and rear drums.
for an lsd/rear discs you need an xr4x4 rear end, though you need 2wd front uprights and non power steering rack.
Ned.
beware, I've got yellow skin
stephen_gusterson
posted on 7/9/04 at 01:31 PM Reply With Quote
if you dont know the manufacture dates, ya cannie define early
1982 to 1993 or summat? So, to be really picky, mid life or before
atb
steve
Ned.
[Edited on 7/9/04 by stephen_gusterson]
Mark Allanson
posted on 7/9/04 at 06:18 PM Reply With Quote
The advantage of the 2.0i is that it comes with the 205 block which is much stronger, and an unleaded head. Dropping the plenum is not difficult or expensive and saves the cost of twin 45's.
Another advantage is that the whole donor will be newer, possibly less miles, and easier to get hold of - when was the last time you saw a 1983 sierra in or out of the scrapyard?
ned
posted on 8/9/04 at 08:36 AM Reply With Quote
Mark means a 2.0 sohc with injeciton, not the dohc.
Ned.
posted on 8/9/04 at 05:47 PM Reply With Quote
i agree with the above. There is no perfect donor cos you want an LSD, but need 2wd front hubs (to my knowledge, all LSDs were in 4x4 cars.)
