number-1
posted on 29/7/12 at 07:43 PM |
push pull control cable question
Afternoon folks
Im having problems with my gear change on a BEC. its using the push/pull control cable for changing gear but its not allowing me to change gears...i
can sometimes get it ito 1st but cant get it back to N. Does anyone know if the sheath at the engine end should be able to come away from like it has
in my pic? The sheath has moved towards the end of the cable leaving the wire inside to flex
![](http://i45.tinypic.com/xdatk5.jpg)
PAUL FISHER
posted on 29/7/12 at 07:51 PM |
No they should be both fixed to the end of the cable, like mine in this photo
[img]
![](/galpreviews/FOR SALE.jpg) ![MK PADDLE SHIFT FOR SALE](/gallery/FOR SALE.jpg) MK PADDLE SHIFT FOR SALE
[/img]
number-1
posted on 29/7/12 at 07:53 PM |
Cheers Paul
With the sheath moved at the engine end, would that allow enough slack in the wire to prevent a gear change? or could there be more to my list of
problems?
Mr C
posted on 29/7/12 at 07:58 PM |
They look a bit knackered. It looks like one has moved out and the other gone in. There's a few rubber seals missing as well. An mage of mine
for comparison if it helps
Girl walks into a bar and asks for a double entendre, so the barman gave her one
PAUL FISHER
posted on 29/7/12 at 08:00 PM |
Yes I would say that is almost certainly your problem, cable tec is your best place to get a new one if you can't fix yours, cheap as
chips
http://www.cable-tec.co.uk/Products/Push_Pull_Cables.asp
number-1
posted on 29/7/12 at 08:11 PM |
Cheers Paul, ive just sent an email with a couple of pics
rachaeljf
posted on 29/7/12 at 09:02 PM |
Mr C, what car is that gearchange off? It looks just right for one of my projects.
Rachael
Mr C
posted on 7/8/12 at 09:46 PM |
Rachael
Apologies for the delay in responding. Its from a GT4 Celica, the gearstick is inverted in the housing and then its actually mounted upside down, to
get the bellcrank orientated for my application, if that makes sense.
The cable mounts and top plate are one off's though let me know if you need them and I may able to sort something
[Edited on 7/8/12 by Mr C]
rachaeljf
posted on 7/8/12 at 10:06 PM |
No worries, thanks for that. I did something just like that for my V6 X1/9's cable change; had to invert the stick and spin it 180 degrees.
I'm doing another cable change conversion project now and it's handy to note sources of nice compact bellcrank arrangements.
Cheers R
