beaver34
posted on 21/8/12 at 05:33 PM |
what fasteners?
hi need to secure my bonnet in two places to stop it rattleing when on the move, want something neat and tidy didnt really want big up and over catchs
like on the sides of the car
any ideas?
its either side of this inlet pipe
thank you
Toprivetguns
posted on 21/8/12 at 05:40 PM |
A nice sexy AEROCATCH would do the job or dowel pins from the bonnet into the nose cone.
http://www.aerocatch.com
[Edited on 21/8/12 by Toprivetguns]
Only drive as fast as your angel can fly... !
stevebubs
posted on 21/8/12 at 05:48 PM |
I would suggest glassing something to the underside to make a lip...
FuryRebuild
posted on 21/8/12 at 05:59 PM |
+1 for aerocatch. they're simple to fit, flush, locking if you need it, weigh nothing.
www.furyrebuild.co.uk
beaver34
posted on 21/8/12 at 06:08 PM |
like this one?
http://www.aerocatch.com/aerocatch3
FuryRebuild
posted on 21/8/12 at 06:10 PM |
Yup - I've got them on my fury, after my original fittings (I adapted TVR strikers and sliders so that I could mount the whole lot inboard and
make it look very neat. All well and good until the cables started popping off. Not TVRs fault I may add.
Then went to aerocatches - they're not expensive for the time and ease of fitting.
beaver34
posted on 21/8/12 at 06:18 PM |
ok great, they look perfect, ill stick the bodywork back on tonight and order a set. where is the best place to buy from? or a case of searching for
the cheapest
FuryRebuild
posted on 21/8/12 at 07:33 PM |
Just go hunting for the cheapest.
IIRC, they do a couple of different sizes, and locking or not. You have choices.
Mark
beaver34
posted on 21/8/12 at 07:44 PM |
Mark
thank mark,
might see your around i spend a fair amount of time harrogate way friend has a garage in Hampsthwaite
Stott
posted on 21/8/12 at 07:48 PM |
Aerocatches are massive though, you don't want one of them either side of that inlet it'll look weird in my opinion, get dzus fastners or
something subtle like that.
If you fancy aerocatches go ahead but check the dims first and cut some out of cardboard and lay em on the bonnet first. Once you've cut em in
there's no going back
atb
Stott
jacko
posted on 21/8/12 at 07:54 PM |
http://www.ebay.co.uk/itm/FLUSH-FITTING-CAB-LOCKER-LOCK-CAMPER-COACH-BUS-TRUCK-/310265962717#ht_1251wt_952
I used these on the boot of my indy
Jacko
![](/galpreviews/IMGP4112.JPG) ![Description](/gallery/IMGP4112.JPG) Description
[Edited on 21/8/12 by jacko]
Or this
http://www.ebay.co.uk/itm/Horsebox-Truck-Trailer-Flush-Compression-Latch-Lock-II-/200645519332?pt=UK_Horse_Wear_Equipment&hash=item2eb767a7e4#ht_5
00wt
beaver34
posted on 21/8/12 at 08:05 PM |
atb
Stott
will do scott,
would alloy be ok to use?
the dzus ones would need some fibreglassing alloy strips to allow fitting as there is no real lip for them to sit onto
like these
Pro Bolt Aluminium D-Ring Quick Release Fastener 14mm Long In Black | eBay![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
FuryRebuild
posted on 21/8/12 at 08:14 PM |
Beaver
Sure - ping me when you're over. I'm rebuilding at the moment so there's lots going on.
I think Stott has a point - will you be happy with the size? Also, they take paint, so you can make them vanish a bit
thanks
mark
beaver34
posted on 21/8/12 at 08:31 PM |
Beaver
thanks
mark
Going to mesure in morning, not fussed about seeing them they won't be the most eye catching thing sticking out of that bonnet!
everest
posted on 23/8/12 at 11:19 AM |
HI,
Have you got room to fit the Dzus fastners,Just need to check the depth of the material and order the correct ones from there. Demon Tweeks etc stock
them.
Hope this helps,
Chris.
RK
posted on 26/8/12 at 12:52 AM |
BONNET BOOT HOOKS WESTFIELD CATERHAM 7 DAX LOCOST COBRA | eBay
what's wrong with these? They hold mine and others on very well, with no vibration problems.
The Black Flash
posted on 28/8/12 at 08:37 PM |
I'm guessing that they wouldn't get through IVA.
RK
posted on 28/8/12 at 10:15 PM |
They would with covers you could easily make.
beaver34
posted on 29/8/12 at 06:06 AM |
At all ready been through sva in 04 so I'm lucky in that respect
The Black Flash
posted on 29/8/12 at 02:04 PM |
Well I'm sure they could, but it's probably the reason why people don't use them much...you did ask ![](/images//smilies/smile.gif)
beaver34
posted on 3/9/12 at 05:29 PM |
fitted these, work fine abit of messing getting the length right though
just need to tidy all the bodywork edges now
![](http://i64.photobucket.com/albums/h161/wideka/vw%20stuff/CC8DD25B-CADB-48D7-9D17-E948D0BF4A5E-3761-000002960C913F35.jpg)
