New Topic New Reply
Author: Subject: Flat stock brackets
Chris_R
posted on 12/9/04 at 07:18 PM Reply With Quote
Flat stock brackets
Does anyone know off-hand whether you can buy 40mm x 3mm flat stock? Gotta be easier to make brackets from that than plate.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
mangogrooveworkshop
posted on 12/9/04 at 07:52 PM Reply With Quote
Just get the fabricators to cut it with his gillotine
Viper
posted on 12/9/04 at 08:01 PM Reply With Quote
If you want, i can make your brackets for you, for a price, you will need to give me a sketch of what you want .
Tim
Chris_R
posted on 12/9/04 at 08:12 PM Reply With Quote
Asked our local guys and they quoted more for 40x116x3 plates than GTS charge for a full set of complete brackets.
Viper, what's your price?
posted on 12/9/04 at 09:39 PM Reply With Quote
Yes you can,
I've got a length in the shed. Are you using the Triumph bushes?
Chris_R
posted on 12/9/04 at 09:44 PM Reply With Quote
Had intended to but from GTS for the majority of the suspension components. Was gonna get bushes off them too.
twinturbo
posted on 12/9/04 at 09:51 PM Reply With Quote
I use 50x50x3mm box with one side cut off. Nice and easy.. distance between inner faces works out at 44mm
TT
Viper
posted on 12/9/04 at 10:00 PM Reply With Quote
Let me know what you want, IE: dimensions etc and how many and i will sort out a price for you.
Tim
Mix
posted on 13/9/04 at 04:27 PM Reply With Quote
Ditto Twin turbo's reply
Mick
Cita
posted on 15/9/04 at 07:28 PM Reply With Quote
Same like Twin turbo.Did them all with a hacksaw and some ellbow grease!
Chris_R
posted on 15/9/04 at 10:06 PM Reply With Quote
I was looking for book spec brackets, but reclaimed a steel sign today that just happens to be made form 50x50x3 RHS.
Cita
posted on 16/9/04 at 03:31 PM Reply With Quote
"just happens to be made from 50x50x3"?
You dont expect us to believe that are'nt you?
Chris_R
posted on 16/9/04 at 05:22 PM Reply With Quote
It's true. It's a bit bent though. Came from a car park that is frequented by a number of learner drivers. Looks like someones reversed into it. Gonna slavage what I can, but dunno how many brackets I'll get from it.
Cita
posted on 16/9/04 at 06:12 PM Reply With Quote
I made 16 brackets out of a 1 meter length of 50x50x3 and still have some length left over.
So that steel sign, even with a bent,should be plenty.
I actually was wondering what you meant by reclaiming Chris?Did you just steal it as i would do
Chris_R
posted on 16/9/04 at 08:28 PM Reply With Quote
Nah, I spent a couple of hours yesterday with a breaker getting it out of the ground. I work for a sign company so have had to fabricate a replacement to the same spec. As jobs go it's quite handy. I've also just cut my floor and rear bulkhead from another reclaimed sign panel. If I was gonna pinch it I'd have prolly used a stihl saw. Would be much quicker.
Cita
posted on 17/9/04 at 12:36 PM Reply With Quote
,you are too honest Chris!
New Topic New Reply
