Author: Subject: front splitter
tcr
posted on 8/9/12 at 02:18 PM Reply With Quote
front splitter
decide to make myself a front splitter today using 6mm marine ply with 3mm carbon effect abs plastic bonded onto it. not sure if it will have any effect on high speed corners like gerrards but at least it looks good ( well i think it does )its secured at the back. to the chassis and hanging basket looking brackets at the front.
here it is btw the jack isn't a permanent fixture
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
Fred W B
posted on 8/9/12 at 05:08 PM Reply With Quote
I would paint the outwards facing edge black to finish it off.
Fred W B
tcr
posted on 8/9/12 at 05:16 PM Reply With Quote
i have now and its got edging trim too ,i was too inpatient to wait till it was finished to take a pic
[Edited on 8/9/12 by tcr]
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
Steve Hignett
posted on 8/9/12 at 10:31 PM Reply With Quote
Did you put any thought into making it a bit wider and taking it a bit further back at all?
tcr
posted on 8/9/12 at 10:56 PM Reply With Quote
you cant really see on the pic but it runs up-to the wishbone mount ,it has a full flat floor so didn't bother extending it any further and i did make a wider template but it didn't look right .
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
Bare
posted on 9/9/12 at 01:19 AM Reply With Quote
Few years back.. on Blatchat there was serious experiment with what you have cobbled together.
IIRC the conclusion was that it Effed the handling noticeably.
Contrary to all assumptions/expectations.
It significantly reduced downforce on the rear wheels.. Not Good.
Aero and Sevens are mutually exclusive :-)
tcr
posted on 9/9/12 at 01:39 AM Reply With Quote
what car was it they used as mine got the engine in the back which makes it 90kg heavier at the rear than the front, that with the planned rear wing should keep it balanced ( hopefully )
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
