Author: Subject: Fury wheel offsets
probablyleon
posted on 20/9/12 at 02:19 PM Reply With Quote
Fury wheel offsets
My Fury currently has Ford Laser wheels 6" / 19mm offset all round (185s on front and 205s on the back). I'd like to order some Compomotive CXRs but I'm getting conflicting info / advice on sizes and offsets to go for. to start with, should I go for 7" on the back and 6" on the front, or stick with 6" all round? secondly, offset... I pretty sure my current offset of 19mm, the wheels don't fill the arches anything like as much as most Fury's I've looked at. That said, I don't want to go all 'Carlos Fandango' either. I'd be really interested to know what other Fury owners have opted for.
adithorp
posted on 20/9/12 at 02:43 PM Reply With Quote
Mine are et18 and j6.5" front, j7" rear with 185/205 combo tyres.
There's a few odd widths on the rear depending on when/where it was supplied and what spacers they had on the hubs. et18ish seems to be the recommended offset though.
http://jpsc.org.uk/forum/
edsco
posted on 20/9/12 at 04:43 PM Reply With Quote
I race a Fury in RGB and found a marked improvement in handling going from the 6" rims to 7". There are arguments for and against should it 6" or 7", but personally i feel the cars handling is vastly improved as a result. 13"x7" for ref with a 23ET Pro Race 1.2. But that is a guess on the ET. Running 185/60 front and 205/60 rear on A048r's
edsco
HowardB
posted on 20/9/12 at 05:23 PM Reply With Quote
mine are ET18 too, 195's on 15" rims. Looks ok. Seem to recall a discussion with Steve at Fury suggesting that some ET30ish that I was looking at would be all wrong,..
HTH
Howard
mazie
posted on 20/9/12 at 05:44 PM Reply With Quote
I run the exact same setup as Adithorp
avagolen
posted on 20/9/12 at 07:55 PM Reply With Quote
Hi, Wheel sizes? what a minefield.
My car is still under construction, so I cannot say how it drives, but after posing the same question
some time ago, I have ended up with 6x13 et16 0n the front and 7x13 et -7 on the rear.
Looks realy nice with the deep dish.
Tires are 185 60 13 & 205 60 13.
I have the spider rear tub and the wheels 'just fit'
see the rear wheel on here.
Sill_Trial_fit
Sill_Trial_fit
HTH
Len
probablyleon
posted on 21/9/12 at 07:06 AM Reply With Quote
Thanks for the info. I'm now airing towards 6" on the front and 7" on the rear. When I was going to use 6" all round I was thinking an ET of 0 on the back might be in the right ballpark but adding an extra inch has slightly complicated things (at least for my underpowered brain)
