YODI
posted on 14/10/12 at 08:54 AM |
Help me secure my dash
Hi guys
I have looked through all the posts in this section and not actually come up with an answer for what I need.
How have you guys secured your carbon dashboards to your cars?
Also, what edge trim can I use to go over the top of the carbon around the edges?
Here are a couple of pics, the carbon is 2mm thick and there is a decent enough edge on the car to secure it too.
Thanks, Yodi
![](http://img.photobucket.com/albums/v87/rsyodi/kitcar/B3E5C91C-6D1F-4F08-BD20-0A33792BA046-1781-0000004DCD6EDA57_zps844a4dde.jpg)
big-vee-twin
posted on 14/10/12 at 09:11 AM |
Mine is not strictly carbon, but GRP covered with Di-Noc.
I have used a rubber u section trim around mine for 2-3mm thick panels and it looks quite good, fixings will be allen key stainless button head screws
with rivnuts into the scuttle
[img]
![](/galpreviews/dashfitting .jpg) ![Completed dash trial fit](/gallery/dashfitting .jpg) Completed dash trial fit
[/img]
http://www.triangleltd.com
YODI
posted on 14/10/12 at 09:12 AM |
I found some on ebay, my carbon is 2mm I might go for the 1-2mm, I can hardly see the screw heads in your dash other than the centre one
whitstella
posted on 14/10/12 at 10:46 AM |
+ 1 for rivnuts
big-vee-twin
posted on 14/10/12 at 12:30 PM |
You will see them that's the only one in there at the time I took the pic, below without Di-Noc with screws
[img]
![](/galpreviews/cowl fitted.jpg) ![Steering Cowl trial fit](/gallery/cowl fitted.jpg) Steering Cowl trial fit
[/img]
stevebubs
posted on 14/10/12 at 04:33 PM |
Motorcycle fairings screws and rivnuts work quite well for fixings...also available in a variety of colours...
theprisioner
posted on 14/10/12 at 05:06 PM |
Alternative fixing method
I wanted as few screws as possible visible on my playskool dash so I devised a method of fixing from behind. The dash is bonded on to a 1.5mm alloy
plate the alloy plate is then bonded on to some of the fixing brackets with Polyurathane adhesive.
![](/galpreviews/nearside fixing.jpg) ![Dasboard fixing](/gallery/nearside fixing.jpg) Dasboard fixing
![](/galpreviews/2012-10-02 20.15.54.jpg) ![Sylva Dashboard in carbon](/gallery/2012-10-02 20.15.54.jpg) Sylva Dashboard in carbon
I can supply more details.
