Author: Subject: 08 R1 Clutch/ engine cutting out
-matt
posted on 16/10/12 at 07:25 PM Reply With Quote
I had my first road drive in my Indy R1 today, and one thing i noticed was the clutch is toast
All i had to do was touch the throttle moderately in any gear and the clutch was slipping, so i will replace the clutch/plates, and preferably some beefier springs.
Is a kit like this what i want : http://www. ebay.co.uk/itm/YAMAHA-YZF-R1-2007-2008-BARNETT-CLUTCH-KIT-LTD-/290435702970?pt=UK_Motorcycle_Parts&hash=item439f5120ba
Will that kit do the job, or do i need something else? could anyone advice on this?
Also i had a problem where, once the engine was very warm, the engine was idling so low, it was stalling, the only way was to keep constant throttle on.
I understand this is a common problem with the 08 R1's with electronic throttle/ no idle screw. What is the best way to overcome this?
The only way i can think of is to fit a widget between the throttle cable, so the throttle is constantly on slightly?, but this would mean the engine would rev quite high cold.
So is there a better fix?
adithorp
posted on 16/10/12 at 09:24 PM Reply With Quote
Generaly it's thought that genuine yamaha plates and steels are the best but use Barnett spring kit. Have you got enough free play in the cable?
http://jpsc.org.uk/forum/
renetom
posted on 17/10/12 at 07:38 AM Reply With Quote
clutch
Hi
As adithorp say's check there is freeplay , the R1 clutch is a bit like an on & off switch
and easy to set up wrong, we have an older R1 2001 carbed version & the standard clutch is fine
even 2 up there has never been any sign of slipping .
The conversion is of course up to you.
had designed a longer clutch lever, which should give more feel to the clutch
However my son say's he has got used to it now, so it was never done.
See our archive
Good luck
René
-matt
posted on 17/10/12 at 08:45 AM Reply With Quote
Its not a cable issue, there is a fair bit of slack.
But i do remember when i took the clutch apart during the build, i noticed a couple of the steel plates were discoloured/a purple burned colour.
So i think its likely the clutch was given some abuse when in bike form!
So I'm best getting the plates/steels straight from yamaha, then just buy the barnett spring kit?
adithorp
posted on 17/10/12 at 09:32 AM Reply With Quote
Yes, thats what I'd do.
People have had problems with aftermarket plates not lasting long. If there's blue-ing on the steels they should be changed.
Mine started slipping after about 3-4000 miles in the car (just occationally on full throttle) with the standard set-up. I changed just the springs and it's still going strong at 18000miles and lots of abuse later. Getting the pedal leverage right so you have a reasonably long movement helps. Otherwise you have a very "binary" clutch (either on or off) and leads to lots of slipping/revs to set off.
-matt
posted on 18/10/12 at 05:45 PM Reply With Quote
I ordered some new genuine yamaha clutch plates and steels from my local yamaha dealer earlier.
My only issue is, he said something about i need to install what he's ordered me, then measure the stack, then he will order the last 2 plates dependant on this measurement?
Is this right? never heard about this before.
Oh and I've just taken the clutch apart, and this is what my steel plates look like!
Oh and also I noticed the 6 spring bolts were a bit loose! I'm guessing this was probably the main cause of the slipping?
[Edited on 18/10/12 by -matt]
