Author: Subject: Steering advice
rincewind23
posted on 21/10/12 at 06:32 PM Reply With Quote
Steering advice
Hi all,
Looking for a bit of advice from peeps who have done similar before..
I'm building a McSorley 442 with a Rover v8 engine in it. This means I need to put a "kink" in the steering column. I think I need to fit a straight piece to the steering rack, then a UJ, another straight piece, then another UJ to connect to the steering column.
I was hoping to get some thoughts on connections. I can't seem to find any straight female spline connectors for the steering rack connector, and should I use spline connections for all the other parts? i.e. both ends of the middle section, and replace the triangle on the end of the steering column with a male spline.
KEv.
austin man
posted on 21/10/12 at 08:04 PM Reply With Quote
had to do the same for a Zetec mk steering
mk steering
T66
posted on 21/10/12 at 08:05 PM Reply With Quote
Not mine, but from my archive.
rincewind23
posted on 21/10/12 at 10:54 PM Reply With Quote
Thanks for the photos, guys.
So am I correct in thinking that in both cases, there is a UJ directly on the steering rack, and another one further out?
