<<  1    2  >>
Author: Subject: Non-firing cylinder
clairetoo
posted on 25/10/12 at 04:14 PM Reply With Quote
Non-firing cylinder
After all the faffing about with my V6 Mx5 , which has got me nowhere ( ) , I seem to tracked down the basic problem - one cylinder isnt firing .
I have changed everything - injector , wiring , plug , swapped the plug leads , and just done a leak-down test .
It was the same as the next cylinder - just over 10% - with no audible leaks from the throttle body , exhaust or breather .
So - what the fudge is going on ? Pulling a plug lead off any other cylinder causes the engine to nearly stop , but has no effect on that cylinder , which also pops flame from the throttle body when revved .
Any suggestions welcome !
Its cuz I is blond , innit
Claire xx
Will weld for food......
Jon Ison
posted on 25/10/12 at 04:22 PM Reply With Quote
Got a spark ?
The next thing I would look at is can you see the injector down the inlet tract ? If so is it injecting, in my experience its usually lack of fuel rather than lack of spark on fuel injected cars cuasing this problem.
clairetoo
posted on 25/10/12 at 04:29 PM Reply With Quote
I have a spark , and on removal from the engine the plug from the offending cylinder is wet - so I have spark , fuel and compression .
I just checked my TDC mark , and its spot-on - checked the timing with a timing/advance light and its spot-on .
Claire xx
rb968
posted on 25/10/12 at 04:37 PM Reply With Quote
Weird one Claire. Spark and wet plug?
Have you got a spare coilpack to try? In case its broken down on that one lead?
Sorry only thing I can think of on top of what you have tried.
Rich
clairetoo
posted on 25/10/12 at 04:42 PM Reply With Quote
I have tried swapping the two leads on that part of the coil , and nothing changed - I've spent two days off and on swapping and changing stuff , to no effect
Claire xx
jollygreengiant
posted on 25/10/12 at 04:56 PM Reply With Quote
Are the valves on that cylinder opening properly, First garage I worked in one mechanic had a V8 Yank with a misfire on 1 cylinder. He changed the distributor, serviced the carb, removed the head and over-hauled them, changed the coil, changed the leads, did the heads again. Then one day he was running the engine with the rocker covers off and noticed one of the valve rockers was barely moving. Turned out one of the cam lodes almost made a perfect bearing cos' it had worn round(ish).
Just a thought.
DIY Si
posted on 25/10/12 at 05:07 PM Reply With Quote
Could it over-fuelling that one cylinder? An injector sticking open would cause roughly what you're seeing.
Sun Tzu, The Art of War
clairetoo
posted on 25/10/12 at 05:34 PM Reply With Quote
I've now tried four different injectors in that cylinder !
Claire xx
ashg
posted on 25/10/12 at 05:56 PM Reply With Quote
you say you have spark. is that when you pull the ht lead off? have you actually checked that the spark plug is working? hows the finger getting on?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
DIY Si
Ummmm.......
clairetoo
posted on 25/10/12 at 06:01 PM Reply With Quote
I've gone through a complete set of plugs from a spare engine , tried the old trick of heating the plug before fitting - I have a good spark at the plug , but nothing once its in the engine .
Edit to add - the fingers are still sore , two of them dont bend at all
[Edited on 25/10/12 by clairetoo]
Claire xx
on_eighty_runner
posted on 25/10/12 at 06:05 PM Reply With Quote
assuming spark plug is ok, (swap with one from another cylinder)
The inlet valve make be stuck open . You mentioned flames in its inlet tract,
No other route for flames unless timing on that individual cylinder is miles out. (spark during induction stroke)
clairetoo
posted on 25/10/12 at 06:15 PM Reply With Quote
Thing is - the leak-down test showed no problems . I've been pulling and swapping plugs all day.........and surely a timing issue would effect all the cylinders , not just one ?
Claire xx
Nickp
posted on 25/10/12 at 06:22 PM Reply With Quote
Has it got hydraulic lifters? Faulty one keeping a valve open maybe? You've done a leak down test, but have you done a compression test?
[Edited on 25/10/12 by Nickp]
clairetoo
posted on 25/10/12 at 06:29 PM Reply With Quote
Could that happen - it does have hydraulic followers , could they `pump up' when running , but leak out when stopped ?
One `test' I have done is simply to place the palm of my hand on the top of the throttle body , it sucks my hand hard to the `body , but doesnt slow the engine at all .
Claire xx
Nickp
posted on 25/10/12 at 06:35 PM Reply With Quote
It is possible. Does it spit back against your hand when you do that test? Mind those pinkies
sebastiaan
posted on 25/10/12 at 06:38 PM Reply With Quote
Blocked exhaust primary maybe?
We're running out of options here.... Maybe it's voodoo?
posted on 25/10/12 at 07:09 PM Reply With Quote
Just because you get a spark testing with the plug out doesn't mean there is a spark under compression, the voltage required to jump the spark plug gap is much higher under compression. At these high voltages the insulation of the coil pack or distributor cap as to be in top class order or the spark will jump to earth.
clairetoo
posted on 25/10/12 at 07:10 PM Reply With Quote
Nope , no spitting at all (at tickover)
I am being careful - I'm using the other hand for testing stuff
Claire xx
Nickp
posted on 25/10/12 at 07:12 PM Reply With Quote
A colourtune kit might help you see what's happening spark wise.
posted on 25/10/12 at 07:24 PM Reply With Quote
As Jolly green giant has already suggested check that the valves are opening, I wouldn't be suprised if the exhaust valve isn't opening which would give you compression but not allow the cylinder to fire properly causing spitting back through the throttle body and a wet plug. I've had similar symptoms a few times, a couple of times it was due to worn(read non existent )cam lobes and another was due to a tappet adjuster coming loose
adithorp
posted on 25/10/12 at 07:48 PM Reply With Quote
Agreed. Seen it years ago on a RangeRover that had 2 exhaust cam lobes worn down to nothing. had compression, spark and fuel but wouldn't fire on those 2 cylinders.
http://jpsc.org.uk/forum/
clairetoo
posted on 25/10/12 at 07:59 PM Reply With Quote
Thanks for the suggestions guys - looks like tomorrows job is to pull the cam cover off that bank , and have a good look .
I do have plenty of spares - the Fury engine just happens to have dead rings and a broken cam belt
Claire xx
ashg
posted on 25/10/12 at 11:53 PM Reply With Quote
Not having much luck at the moment are you.
posted on 25/10/12 at 11:59 PM Reply With Quote
An air leak on the inlet manifold/throttle body is a possibility. That would account for both the flame spitting activities and not running at idle, as well as not affecting a leak down test.
[Edited on 25/10/12 by MikeRJ]
<<  1    2  >>
