Author: Subject: Anti-roll Bar kit - Raw Striker
sooty
posted on 25/10/12 at 11:07 PM Reply With Quote
Raw Striker - Anti-roll bars
Can anyone tell me who supplies a Kit for fitting front and rear Anti-roll bars with a live rear axle.
Or any tips of how to make my own with dimensions etc.
jeffw
posted on 26/10/12 at 03:51 AM Reply With Quote
A guy called Rob Farley makes a front kit that is designed to fit. You can find him on the JPSC forum or http://www.clubstylus.be/ which he runs. If you are using the standard metalastic bushes in the rear you will not need a rear ARB as Jeremy designed it to work without. If you have rose jointed the rear then you will need to make something.
INDY BIRD
posted on 26/10/12 at 05:47 AM Reply With Quote
Is that the same for a IRS car or do they need rear arb aswell?
Thanks for the post and info as I'm interested in a set also,
Cheers sean
jeffw
posted on 26/10/12 at 07:13 AM Reply With Quote
I don't know is the simple answer. I know people who only run Rob's front ARB in an IRS Phoenix but as to if this is correct I don't know....did make him go faster when it was fitted though.
matt_gsxr
posted on 26/10/12 at 08:22 AM Reply With Quote
I have one of Robs bars on the front of my Phoenix, which is similar to Striker. I suspect this bar is a bit on the stiff side of ideal (bike engine), but it made a huge positive effect on handling. Previously the inside rear wheel would life a bit giving tricky handling and with the bar it doesn't. I have fairly weak springs (180lb/inch front, 150lb/inch rear).
Regarding rear ARB, you can fit a caterham rear arb (~£40), and DIY the pivots (hydraulic pipe clamps) and drop-links, but I am fairly sure that it is the front one makes the big difference.
Matt
bi22le
posted on 26/10/12 at 08:42 AM Reply With Quote
hmm, interesting read.
softer springs and ARB on the front is something I am also considering.
Please read my ring story:
jeffw
posted on 26/10/12 at 09:46 AM Reply With Quote
I run one of Rob's front ARBs with 250lb front and 180lb rear.
matt_gsxr
posted on 26/10/12 at 09:57 AM Reply With Quote
But you have a boat anchor up front
adithorp
posted on 26/10/12 at 12:59 PM Reply With Quote
He does occationally. More often than not recently he's had an empty engine bay...
http://jpsc.org.uk/forum/
JimSpencer
posted on 26/10/12 at 01:19 PM Reply With Quote
Hi
I was asked by Matty78 re set-up the other day
Track Suspension thread
Basics are as the above - are front ARB a must IMHO, rear not required on live axle (dont think many of the IRS lads run them either) - don't go too stiff on the springs and have the geometry professionally done!
HTH
jeffw
posted on 26/10/12 at 03:08 PM Reply With Quote
very drole
philw
posted on 26/10/12 at 05:54 PM Reply With Quote
I have a front kit that i bought ages ago, but I sold the car before I had a chance to fit it, Ill see if i can find all the bits
Must try harder
DH2
posted on 26/10/12 at 08:49 PM Reply With Quote
Originally posted by philw
I sold the car
And now look at the state of the poor thing...
DH2
[Edited on 26/10/12 by DH2]
rost
posted on 29/10/12 at 10:41 AM Reply With Quote
Also running one of Rob's ARBs on the striker. I really like it, especially because most strikers run fairly soft springs.
He's very nice guy and the ARB is well made too.
Charlie don't surf!
lsdweb
posted on 22/1/15 at 10:06 AM Reply With Quote
Hi All
Sorry for dragging up an old thread but does anybody have contact details for Rob Farley as I'm looking for a front antirollbar for my Striker.
Ta
Wyn
peter030371
posted on 22/1/15 at 02:56 PM Reply With Quote
Does anyone do an ARB for the rear of an IRS Striker?
bi22le
posted on 22/1/15 at 04:49 PM Reply With Quote
Read earlier in the thread, someone mentions that a Caterham one fits with some ingenuity.
jeffw
posted on 22/1/15 at 05:51 PM Reply With Quote
Originally posted by lsdweb
Hi All
Ta
Wyn
Wyn
I've texted Rob and he will contact you. Let me know if you have not heard anything in a few days and I'll chase him up.
lsdweb
posted on 22/1/15 at 06:13 PM Reply With Quote
Many thanks Jeff
peter030371
posted on 23/1/15 at 02:12 PM Reply With Quote
opps, I missed that bit
