Author: Subject: dry sump oil and water system help
daniel mason
posted on 31/10/12 at 11:02 PM Reply With Quote
does anyone have a layout of the oil system pipework for the sbd dry sump kit?
and also the coolant system with electric waterpump set up?
all for the hayabusa engine,cheers
Andy B
posted on 1/11/12 at 12:11 AM Reply With Quote
Hi Daniel
Done a fair few of these, give me a bell and I will talk you through it
Best regards
T66
posted on 1/11/12 at 09:32 PM Reply With Quote
Daniel are you aware SBD have a pdf install thing on their site ?
infact here it is
http://www.sbdev.co.uk/Info_sheets/Hayabusa/Hayabusa%20Dry%20Sump%20Instruction%20Sheet.pdf
[Edited on 1/11/12 by T66]
big_l
posted on 2/11/12 at 12:03 AM Reply With Quote
Plenty of pics on my blog mate !
Check out my blog mnrvortxhayabusa@blogspot.com
daniel mason
posted on 2/11/12 at 07:11 AM Reply With Quote
cheers guys, its the plumbing ivan. ive fit the dry sump without problems, but am unsure of the plumbing.
ive looked in your blog mate but cant see any clear pics of your plumbing. i only haveone inlet on the sump pan and one outlet on the scavange pump. with 2x couplings from scavange pump to pan
Andy B
posted on 2/11/12 at 08:36 AM Reply With Quote
Hi Daniel
SBD set up as follows,
twin scavenge ports are connected directly to scavenge pump via o ringed tubes
outlet port on pump to feed into dry sump tank via oil cooler if fitted
bottom connection of tank gravity feeds inlet on sump pan which in turn feeds onboard oil pump
THERE IS AN ALLEN BOLT FITTED IN THE RELIEF PORT INSIDE WHERE THE OIL FILTER SCREWS ON, DEPENDING ON SET UP THIS WILL NEED TO BE REMOVED SPEAK TO STEVE BROUGHTON FOR ADVICE ON THIS ONE
hope that helps
daniel mason
posted on 2/11/12 at 09:59 AM Reply With Quote
Thanks andy, didnt want to bother you with another call.
I have removed the allen bolt inside oil filter housing as per sbd instructions,
thats is how i thought it was plumbed but the second hand d/s kit i got has 3x hoses and 6 ends. Is one a breather?
Also how do i plumb the electric water pump into the coolant system, with header tank and rad?
Engine has 2 outlets close to each other but one slightly lower than the other
big_l
posted on 3/11/12 at 06:52 PM Reply With Quote
On the engine send the highest water outlet 19mm to top of rad bottom water outlet on engine water pump on bottom hose with direction of flow towards the engine .
Bottom hose from header tank needs t piece into bottom rad hose this is to top up water system if required
On the top water outlet from engine is a small bleed pipe this goes to top of header tank and also if the rad has a bleed pipe at the top T this in too the top header tank hose 8mm?
Hope this helps
daniel mason
posted on 3/11/12 at 07:48 PM Reply With Quote
so the top 25mm outlet to top of rad,
lower outlet to waterpump with flow direction back towards engine, and other side of pump to bottom rad hose.
bottom of header tank t'd into bottom hose
bleed from top outlet to top of header tank?
cheers mate
big_l
posted on 4/11/12 at 06:05 PM Reply With Quote
Yes if the rad has a bleed pipe on the top then put that to the top of the header tank also
