Humbug
posted on 3/11/12 at 02:21 PM |
Made a clock from an old speedo
I saw this nice old Cortina speedo on ebay...
...and thought I could make that into a nice retro desk clock with a car theme. £7.40 and a week later it was mine
£4.50 for a quartz clock mechanism and hands:
Use of hacksaw, drill, jigsaw, taps, add in some M5 set screws, washers, an M8 bolt, nyloc and washers, a piece of spare ali sheet, a piece of spare U
trim, a glue stick or two, some primer and satin black paint, Mariner Blue touch up paint for the hour and minute hands and voilą, I can now easily
tell when it's 30 to 80
I had to get rid of the original mounting bracket, drill through the speedo face for the clock spindle, and glue the mileage dials together then cut
them down so they didn't get in the way of the clock mechanism. I used the cut-off back of the original casing to make the base. The back plate
is spaced away from the rear of the casing so the hands clear the glass; I could have got a clock with a shorter spindle but I went for the longest
one available and in the end didn't need it. Never mind.
Simon
Confused but excited.
posted on 3/11/12 at 02:26 PM |
They'll all want one now.
morcus
posted on 3/11/12 at 02:29 PM |
That is brilliant.
Would be great if you could set the odometer to say the date.
russbost
posted on 3/11/12 at 02:30 PM |
That's really neat, one of my customers did a similar thing with a classic mini speedo, he'd put another engine &box in the car so
couldn't use the original speedo, but wanted to keep the look & position as it was, so he mounted an Acewell 70mm speedo in the centre of
the Mini one - I think it looks quite cool!
[img]
[/img]
rachaeljf
posted on 3/11/12 at 02:42 PM |
Hell, it's 33 minutes past 70 already, must get back out to the garage and do something.
Fatgadget
posted on 3/11/12 at 03:39 PM |
SACRILEDGE!
snapper
posted on 3/11/12 at 03:49 PM |
0 to 60 on an old Cortina
You'd need a minute hand
Very cool though, can I have one??
I eat to survive
I drink to forget
Fatgadget
posted on 3/11/12 at 04:01 PM |
Obvious the old 'Tina you are on about didnt have the prefix 'Lotus' and the suffix 'Special Equipment'!
Yes I had one and the speedo read 140 MPH
Ninehigh
posted on 3/11/12 at 04:28 PM |
quote: Originally posted by morcus
That is brilliant.
I was just thinking that!
Humbug
posted on 3/11/12 at 04:58 PM |
It does do 0-110 in about 50 seconds... tha's how long it takes to get that far round the dial
COREdevelopments
posted on 3/11/12 at 05:56 PM |
That's a brilliant bit of work! Looks fantastic!
Rob
