New Topic New Reply
Author: Subject: pics of rear tray setup
noc231073
posted on 4/11/12 at 02:13 PM Reply With Quote
hi guys ,
I am just putting my indy back together after fitting a swirlpot etc at the rear . I have a full cage and and the fuel filler cap has to be in this panel also. Just looking or ideas on how guys get around fiiting the rear panel . As its quite akward dealing with the roll bars . id also like to have a panel that i can open to get access to the swirl pot
thanks
nick
renetom
posted on 4/11/12 at 04:57 PM Reply With Quote
Hi
This is what we did on ours, the aly plate is 1/8" thick & the filler cap is raised about a 1/4" from its surface.
This also adds a bit of rigidity to the rear tub,
filler cap
filler cap
The top panels are a black plastic in 3 sections, 2 small outer ones have the slots, the central one has the
cut outs for the seat belt mountings & a hole for the filler cap, need
to be accurate or it will look like s**t , all is held down with black flange head screws.
The rings hide the back edge of the slots are soft plastic, make the rings slit them & twist to fit over the bars.
we also glued pieces of wood to the underside of the tub for the self tappers to go into & also to the edge of
the small panel on the left for the centre section to sit on & be fixed to.
That way all panels are removable for access.
rear panels
rear panels
Good luck
René
New Topic New Reply
