Author: Subject: Call that a piston?
rodgling
posted on 11/11/12 at 11:40 AM Reply With Quote
Call that a piston?
This is a piston:
From an 148 litre straight 8 diesel making 3600 bhp at 1000 rpm, apparently.
Probably not very locost or light weight though, I will admit.
[Edited on 11/11/12 by rodgling]
maccmike
posted on 11/11/12 at 11:44 AM Reply With Quote
no piccy
flibble
posted on 11/11/12 at 11:54 AM Reply With Quote
My god thats mahoosive
monck
posted on 11/11/12 at 12:01 PM Reply With Quote
Wow that's big !! Bet you'd get a nice car for the cost of one of them ....
omega0684
posted on 11/11/12 at 12:12 PM Reply With Quote
what is it out of?
rodgling
posted on 11/11/12 at 12:18 PM Reply With Quote
Out of this 19 ton marine engine monster:
http://marine.cat.com/cda/files/1377786/7/Cat%203608%20Propulsion%20Spec%20Sheets.pdf
Apparently this one had fuel injector problems and burned the crown of the piston (hence the blueing round the top). The holes in the top of the piston are for attaching bolts so you can lower it into the engine with a crane!
owelly
posted on 11/11/12 at 12:28 PM Reply With Quote
"Can you hear pinking?"
"Nah, sounds OK to me........"BANG!!
Taken from one of our little engines. Piston is about 300mm across.
http://www.ppcmag.co.uk
dave r
posted on 11/11/12 at 01:13 PM Reply With Quote
about the size of the ones i used to work with
somewhere i have a cam roller here that came from one,
also a 12mm bolt that fell in through the exhaust, and got pounded by the piston
will look for them later
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
ReMan
posted on 11/11/12 at 01:40 PM Reply With Quote
Engine Dry Weight
kg (lb)
19 000 (41,800)
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
TheGiantTribble
posted on 11/11/12 at 02:12 PM Reply With Quote
Yeah and I bet we have all had the thought
'I wonder if it would fit...'
even if only briefly
wilkingj
posted on 11/11/12 at 02:24 PM Reply With Quote
It rather Dwarves the piston out of my Frog 1.5cc model airplane engine!!!
Best Regards
Geoff
http://www.v8viento.co.uk
iank
posted on 11/11/12 at 02:31 PM Reply With Quote
All tiny compared to these
http://www.the-bucket-list.com/bigengine.html
Bonus points for spotting the locostbuilder...
[Edited on 11/11/12 by iank]
Anonymous
Daddylonglegs
posted on 11/11/12 at 03:12 PM Reply With Quote
Originally posted by ReMan
Engine Dry Weight
kg (lb)
19 000 (41,800)
Chuffin' 'ell!! and I thought a Pinto was heavy!
will121
posted on 11/11/12 at 07:19 PM Reply With Quote
i done my apprenticeship on large Mirrlees blackstone static 1.5mw generators with pistons like that, two straight 8's bolted together, quad turbo'ed through a common gearbox, still have a dot punch made out of a inlet valve stem
owelly
posted on 11/11/12 at 07:34 PM Reply With Quote
My 'big' engines are Mirrlees KVSS16. Lovely things.
SteveWalker
posted on 11/11/12 at 07:50 PM Reply With Quote
Many years ago I was involved in testing a couple of 250 litre, V12, turbo-charged gas engines. They were beasts - 4500 bhp at 300 rpm. During build, it was easier for the electricians wiring the instruments around the top of the engines to stand *IN* the cylinders! Design life was over 20 years, running 24/7.
owelly
posted on 11/11/12 at 08:34 PM Reply With Quote
My Mirrlees were comissioned in 1959 and have been running (in rotation) ever since!
dave r
posted on 11/11/12 at 09:19 PM Reply With Quote
valve
valve
valves i have
v 16 4 valve per head, 750 rpm twin turbo 5.5 MW alternator on the end mostly at 11kv
