Author: Subject: URGENT advice please!!
fullpint
posted on 10/12/12 at 07:59 AM Reply With Quote
My daily runner (Stilo) is in the garage, using a loan Punto but its boring so today at 630 I fired up the Mk Indy blade.. Into my trip is was running rough! Ok a little cold i thought. Could smell fuel... Pulled over after 4 miles, turned it off and checked my manual choke cable was working. It was. Tried starting it and after a while it fired up on 3 pots... Got to wokr and notice fuel around the 2nd carb plastic top cover??????? Could it be just a jet blocked up..
Feel free to put your advise down as to what it could be and a quick repair to get me home at 3pm with out using toooo much battery juice to fire it up all the time
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
r1_pete
posted on 10/12/12 at 08:28 AM Reply With Quote
sounds like the float / needle valve in No2 carb is stuck, try giving it a few sharp taps, preferably with a wooden mallet or similar, that may dislodge it.
fullpint
posted on 10/12/12 at 08:41 AM Reply With Quote
Thats a good point Pete.. Car is sitting in the sun at the mo warming up. I will get a nice bit of wood and do a gentle tap dance on the carb.... Too cold at the mo!! Got frost on my seat, brrrrr..
sickbag
posted on 10/12/12 at 09:00 AM Reply With Quote
Not sure if it affects them as much in a car as it does on a bike but you can find the carbs suffer from icing when it's this cold - especially if the water heating circuit is blocked or not used at all.
Finally back on the job!
jossey
posted on 10/12/12 at 09:16 AM Reply With Quote
+1 for pete thought.
David Johnson
adithorp
posted on 10/12/12 at 10:19 AM Reply With Quote
+2
http://jpsc.org.uk/forum/
MK9R
posted on 10/12/12 at 12:10 PM Reply With Quote
how long since you last used it?? The orings in the carbs shrink when they dry out, once soaked in fuel for a couple of hours they swell up and seal again. But as others said could be a float needle sticking.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
fullpint
posted on 10/12/12 at 03:15 PM Reply With Quote
New addition to my tool kit now is a wooden mallet... Cheers Pete that seemed to work.. Guess I wont know for sure untill the next frosty morning run.. Tomorrow I will drag the Punto back out and will take the carbs of the Indy at some point just to check em out..
Back home and she ran a treat
r1_pete
posted on 10/12/12 at 05:17 PM Reply With Quote
Glad it worked and got you home.
Anoying thing is you'll no doubt find no evidence of a fault.....
fullpint
posted on 10/12/12 at 06:05 PM Reply With Quote
Again you could be right there. May just leave them alone and just stick with doing a filter and oil change.. And coolant whilsts its up on the stands
