Author: Subject: Inertia (Fuel Cut off) Switch Sensitivity
ChrisJ15
posted on 17/12/12 at 05:10 PM Reply With Quote
I bought a used inertia Switch (Rover) to add to my kit car.
It trips rather more easily than I expected!
If i hold it in one hand and shake it side to side it trips out. I can imagine when its bolted to a kit car with limited suspension it would trip out all the time.
Its difficult to quantify but Im just wondering if anyone has found the same but fitted it and found it to be OK.
posted on 17/12/12 at 06:18 PM Reply With Quote
It will be fine but it must be solidly mounted to a stiff part of the chassis.
pewe
posted on 17/12/12 at 06:21 PM Reply With Quote
IIRC mine was advertised as a Rover one (PBT-GF15), pic. might help identify it.
Actually works fine - in reality it takes a lot of inertia/retardation to activate it - ask my No2 son how I know!
HTH.
Cheers, Pewe10
posted on 17/12/12 at 07:28 PM Reply With Quote
I have a Rover switch in my car, hasn't ever tripped out when driving
johnH20
posted on 17/12/12 at 09:18 PM Reply With Quote
What is the correct orientation for an inertia switch. I have a Ford one ( Fiesta/Puma I think ). Should it be mounted to a vertical or horizontal surface. It is not obvious from the fixing point. Any one know?
theprisioner
posted on 17/12/12 at 09:24 PM Reply With Quote
Also interesed in reply
I have mounted mine at an angle, works ok if I hit it with rubber hammer!
Madinventions
posted on 17/12/12 at 09:27 PM Reply With Quote
My Ford Puma inertia switch is mounted vertically with the red button at the top. Never tripped during nearly 4 years of normal driving on Suffolk Roads or hooning around trackdays. I've been through one or more potholes in my time too and the switch never tripped, but I know my spine felt it!
Ed.
View my band website:
http://www.shadowlight.org.uk
ChrisJ15
posted on 17/12/12 at 10:03 PM Reply With Quote
Thanks for all the advice.
Guess I'll just fit it and stop worrying!
posted on 17/12/12 at 11:33 PM Reply With Quote
Should be mounted vertical, with connector at bottom.
