Author: Subject: Lathe help needed - beer tokens waiting!
chrsgrain
posted on 27/12/12 at 06:24 PM Reply With Quote
Hi all,
I was hoping someone could help - I need to have the bit that holds discs onto a grinder reduced in thickness so my shrinking disc can't hit anything it shouldn't..... a picture is worth a thousand words, this should make things clearer...
See how it pokes out above the plane of the disc - that means it can hit on bits of bodywork which is obviously bad! What I'd like is it turned down so that it lies at least level with the plane of the disc, if not a tiny bit below. The plane of the disc isn't flat, its slightly inclined into the centre, so the attaching disc could do with following that plane, or kept entirely below it - if that makes sense! Another picture may help... Although it doesn't look like it in the picture, there will be enough metal left, especially as there is very little force through the disc when its used.
If anyone is wondering what its for, its for accurately shrinking metal, which helps turn this hole....
via this....
into this... (the dark lines are bits of guidecoat stuck in the grooves from the body file)
Here's hoping someone can help! Cheers
Chris
ReMan
posted on 27/12/12 at 07:49 PM Reply With Quote
Sorry cant help, but thats not natural.
More witchcraft!
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
theprisioner
posted on 27/12/12 at 08:35 PM Reply With Quote
I have done exactly the same thing to my 115mm grinder for exactly the same reason. Unfortunately I am at the opposite end of the country from you. I will send you U2U and you can pop it in the post to me if you want.
Fred W B
posted on 28/12/12 at 07:38 AM Reply With Quote
if you only want to take material off the outside why not just spin it up with a spacer underneath in the place of the disc and apply a flap disc on another grinder to the surface?
Fred W B
[Edited on 28/12/12 by Fred W B]
You can do it quickly. You can do it cheap. You can do it right. Pick any two.
posted on 28/12/12 at 09:23 AM Reply With Quote
Fred W B
I've used the same method with the part held on a bolt or old spindle in the pillar drill chuck and to shape the backs of inlet valves as well.
907
posted on 28/12/12 at 10:10 AM Reply With Quote
Could you form a depressed centre into the shrinking disc?
From your pics it looks as if it's slightly depressed already, and retaining more threads
in the nut would be safer.
If you do "thin" the nut you will also need to shorten the male spindle, or use a spacer.
Paul G
rf900rush
posted on 28/12/12 at 10:50 AM Reply With Quote
Hi
If you do not find any one closer, I am in Epsom Surrey, With a small ish lathe, willing to help.
Could also make a spacer for he back if required.
Martin
chrsgrain
posted on 29/12/12 at 01:11 PM Reply With Quote
Thanks guys for all the suggestions... I think I'll take Martin up on his offer of thinning the part and making the spacer!
Cheers all...
Chris
rf900rush
posted on 29/12/12 at 10:11 PM Reply With Quote
U2U sent
Sadly the Dax Was sold this year.
New project under way but for the kids this time
Just sent to the Painter.
Fortunately I have a brother who Beats Panels and paints, and is now the favorite Uncle.
Primer
Body Primer
Body Primer
Top coat
Body Top coat
Body Top coat
r1_pete
posted on 30/12/12 at 12:36 PM Reply With Quote
Will this do? was in the workshop doing some work on the lathe and remembered your post.
Its an M14 thread, and about 1.5mm thick now, 4mm in the raused centre section....
