Author: Subject: WTD dynojet quickshifter for powercommander
locostbuyer83
posted on 31/12/12 at 08:39 PM Reply With Quote
Hi guys
I've got a powercommander 3 USB and am looking for a quickshifter (push rod type)
Let me know if you can help.
Stu
Johneturbo
posted on 1/1/13 at 11:55 AM Reply With Quote
I'm gona try and make one over the next few weeks for the PCV
all you need is a micro switch(prolly from maplins) to control when to activate the cut in the PC
there are a few threads about it on the interweb
locostbuyer83
posted on 1/1/13 at 12:48 PM Reply With Quote
Oh that's an idea
Found this:
http://www.locostbuilders.co.uk/viewthread.php?tid=139755
Just need to find a switch.
locostbuyer83
posted on 1/1/13 at 08:28 PM Reply With Quote
Other option is this
http://www.ukroadandrace.co.uk/epages/es122068.sf/en_GB/?ObjectPath=/Shops/es122068/Products/%22PK%20ZX12%22
The DIY is not much cheaper but by the time you buy the cable adaptor:
http://www.cordona.net/shop.htm
And found a switch...
And then put it all together and got it working properly...
It's probably easier to get the real thing (or on this case a copy)
[Edited on 1/1/13 by locostbuyer83]
Johneturbo
posted on 1/1/13 at 09:57 PM Reply With Quote
i'm thinking more this!
as from this thread
http://bristolkitcarclub.co.uk/smf2/index.php?topic=1400.0
[Edited on 1/1/13 by Johneturbo]
Davey D
posted on 2/1/13 at 02:48 AM Reply With Quote
Don't you need the ignition module to use the quick shifter on the pc3?
locostbuyer83
posted on 2/1/13 at 08:06 AM Reply With Quote
My zx12 doesn't need it
On motorcycles that have eight injectors and were not previously able to benefit from the use of the Dynojet Quick Shifter, the Ignition Module now allows this functionality. The Dynojet Quick Shifter is connected to the expansion port between the Ignition Module and the PCIIIusb.
Davey D
posted on 2/1/13 at 08:25 AM Reply With Quote
Does that mean that one of these will work on my 2006 R1 5vy? i have a PC3 fitted, and running, and i was given a quick shifter module a couple of years ago, but never fitted it because i presumed i needed the ignition module to make it work?
locostbuyer83
posted on 2/1/13 at 08:53 AM Reply With Quote
I think so. Might be worth a quick google but its only going to have 4 injectors like mine.
locostbuyer83
posted on 2/1/13 at 06:58 PM Reply With Quote
as from this thread
That's got to be worth a try. You can get switches in your local maplin for a few quid and he's not even used the proper connector. All I need is to finish rewiring my car and fit the sump and the interior.. And tax and insure it then I can try it out!
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 2/1/13 at 07:25 PM Reply With Quote
Any good
http://forum.wscc.co.uk/forum/index.php/topic/98972-trickshifter-with-auto-blipper-cycle-wings-uprights/
locostbuyer83
posted on 2/1/13 at 07:41 PM Reply With Quote
Originally posted by CRAIGR
Any good
I've already got a Powercommander so all I want is a low cost upshift quickshift
Johneturbo
posted on 18/2/13 at 05:32 PM Reply With Quote
I got a switch from Maplins as in the piccy, i only run it on axel stands as the car is SORN at the moment but seemed to work fine, i set up the cut for 85ms
not bad for only a couple of quid
PC5 QS switch
PC5 QS switch
