TimC
posted on 2/1/13 at 09:42 PM |
Quick CBS Wiring Module Query
Would I be right in thinking that Number 5 on the diagram below (main alternator connection) is connected within the module to Number 6 on the diagram
(battery via starter).
Many thanks,
TC
umgrybab
posted on 2/1/13 at 09:50 PM |
I think it is IIRC. I can have a check on mine with a multimeter tomorrow if you'd like.
TimC
posted on 2/1/13 at 09:52 PM |
That would be fab if you don't mind.
Cheers.
omega 24 v6
posted on 2/1/13 at 10:40 PM |
Haven't used or seen one BUT logically it should be.
eddie99
posted on 2/1/13 at 10:45 PM |
+1
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
umgrybab
posted on 5/1/13 at 10:00 AM |
Millimeter agrees. These two are directly connected, somewhere in there...
Rich J
posted on 3/2/13 at 04:35 PM |
Hijacking this thread somewhat- I have the earlier version of the module on a Striker I'm rebuilding and 5 and 6 are also conected. The problem
I have is that the battery runs flat as no. 6 is permanently live and conected to number 2 here:
here
The question is - is it safe to conect it to a switched live terminal somewhere else on the module??
The alternator is 40A so should the wire be rated to carry this?
Thanks in advance
Rich![](/images//smilies/wink.gif)
umgrybab
posted on 23/2/13 at 05:49 PM |
here
Thanks in advance
Rich
Hey Rich, did you get an answer to this? I did not check back up on this thread since I last posted. I had the exact same issue you are having a few
months ago and wondering if you still need help.
