darren(SA)
posted on 24/9/02 at 02:17 PM |
clutch stiffness problem
Hi guys,
I've got a 1600 crossflow on a cortina 4 speed gearbox in my locost.
the problem is that the clutch is far too hard to press!
We took the clutch + flywheel off and had it tested but they are both in perfect nick. This leeds us to either the clutch cable or the pedal.
The pedal is the same spec as the original Birkin's, while cluth cable is shorter.However, when disconecting the cable, it moves freely through the
bend by hand. It is my understanding that the cortina has a hydrolic clutch, so could this be the problem?
Feedback would be appreciated
thanks
darren
JohnFol
posted on 24/9/02 at 03:17 PM |
(I presume you mean pressure plate and not flywheel)
I'd do the following.
1) Disconnect the cable from the release leaver. Can you pull the leaver? If not, then it sounds like the fitting of the gearbox. (ie release bearing
not free to move, or splines not central in clitch plate)
2) Re-connect cable to lever and disconnect from the back of the brake pedal. Does leaver move when pulling on the cable? It should move. (remember
you do not have the leverage of the pedal so it will be hard, but not impossible)
3) Check the pedal travels without the cable to prove it is not being fouled or blocked.
4) Re-attach cable to pedal. You know the cable works and the pedal moves. If it now stops moving then the bend is causing the problem.
5) Drink lots of Guinness and use a foot pump to build up that leg muscle.
Highcost builder
posted on 24/9/02 at 04:48 PM |
the clutch cable route is fine you dont need to go hydraulic ive fitted a cable to my x flow and 4 speed box and then to a x flow and 5 speed t9 and
they both worked fine. nice fault let us know what you find.
theconrodkid
posted on 24/9/02 at 05:27 PM |
What cortina did it come out of,mk 1+2 were hydraulic,mk 3 on were cablesounds like you are trying to pull when when the lever wants to be pushed ,if
you get my drift?
Highcost builder
posted on 24/9/02 at 08:09 PM |
good point up there
johnston
posted on 24/9/02 at 09:22 PM |
also is it qh clutch as they can be as heavy as f**k especially if it was on the engine and has sat around for a while
davef
posted on 25/9/02 at 10:36 AM |
hi darren, i also am using 1600xflow & 4 speed c type gearbox from a mk4 cortina. i experienced the same problem as you, so i started to experiment.
at the start the distance from the the pivot point to the cable attachment hole was +- 100mm and was far to stiff so i drilled another hole for the
cable closer to the pivot hole, a definate improvment. after further drilling of holes ever closer to the pivot point it ended with the cable mountng
hole +- 50mm from the pivot. the result was a nice easy action with very little effort required. it,s all down to that old greek guy who said give me
a lever big enough and i will move the world. cheers davef. from durban SA.
darren(SA)
posted on 26/9/02 at 05:58 PM |
Sorry It's taken me this long to get back to you guys, the builders next door chopped my telephone line
JohnFol: I took everything, the flywheel, pressure plate & clutch plate-> they said they were OK.The lever is too hard to move by hand,we've checked
the bearing,checked the splines all seems OK.
Highcost builder: Nice fault? theres no such thing! hehee just kidding.Not giong hydrolic saves me some time& $$$
theconrodkid: It was a MK4, same as davef's
DaveF: It's good to know someone had the same problem as me! I must measure the distance to pivot point and compare it to yours, I'll measure it
tomorrow and perhaps even drill a couple of holes. Won't moving the the hole closer to the pivot point shorten the travel too much?
Thanks for the great response, its much appreciated.
darren
davef
posted on 27/9/02 at 07:58 AM |
hi darren, no the travel will be fine, it actually makes very little difference. but the change in pedal pressure is dramatic.
cheers davf.
paulf
posted on 27/9/02 at 05:53 PM |
I have also found my clutch pedal to be heavy and considered altering the pedal ratio. How much cable travel is needed at the release arm attachment?
i presently have 40mm total travel, but think i only need about 20mm to operate the clutch. Can anyone confirm this?.
Paul.
quote: hi darren, no the travel will be fine, it actually makes very little difference. but the change in pedal pressure is dramatic.
cheers davf.
bran
posted on 27/9/02 at 09:32 PM |
Hi Darren,
If my memory serves me correctly mk 1 and 2 were hydaulic clutch and mk 3 on were cable clutch, the operating difference was the hydaulic pushed and
the cable pulled the clutch lever. This means the clutch operating levers are not pivoted at the same point, the hydaulic is between the cylinder and
the clutch, the cable type is on the other side of the gearbox, don't know if this helps,
regards Colin
bran
posted on 27/9/02 at 09:41 PM |
Hi Paul, regarding cable travel, 40mm travel does seem about right, but I will check the drawing archives on Monday (if they go back that far) and get
back to you.
regards Colin
darren(SA)
posted on 29/9/02 at 10:48 PM |
Hi DaveF,
I measured the distance from the pivot point to the cable, only to find that it is 50mm Do you think it could be the distance from the pivot point
to the bottom of the pedal that is too short(+-210mm)?
thanks
darren
davef
posted on 30/9/02 at 06:13 AM |
hi darren, i will measure it all up tonite, but from memory i am sure mine is longer than 210mm. and i know that the pivot point is elevated above the
chassis top rail, check you tommorow. davef
darren(SA)
posted on 30/9/02 at 07:56 PM |
Thanks Dave!
I'll try measure my pedal again, 210mm was what I remembered.If worst comes to worst, I'm going to take photo's of the whole thing from g/box to
pedal and let you guys have a look!
cheers
darren
davef
posted on 1/10/02 at 06:16 AM |
hi darren, measured the pedal last night,
the distance from the pivot point down to the center of the pedal is 280mm the distance from the floor to the center of the pedal is 185mm, the
distance from the top side of the top rails to the pivot is 130mm the 50mm from pivot to cable hole kicks off at 40degrees towards the front of the
car, that 40 degrees is when the pedal is hanging perpendicular to horizontal. hope this helps davef.
darren(SA)
posted on 1/10/02 at 08:07 PM |
I also hope that helps!I'll compare the specs and let you know.
thanks alot,
darren
darren(SA)
posted on 12/10/02 at 09:11 AM |
Davef!
I measured my pedal up only to find the following differences: My pedal arm is 130mm shorter than yours, which is exactly the distance from your top
rails to the pivot point! This must be my problem, 130mm is a lot of leverage! My pivot point is is line with the top rail where it should be 130mm
above!
Mine is however very much the same as my friend origin birkin, only his has a escort 5 speed box. So it looks like the setup for the cortina's 4
speed and the escort's 5 speed requires a different leverage system.
Hope this does solve my problem
thanks 4 the help,
darren
