Author: Subject: Engine managment
Dooey99
posted on 7/1/13 at 11:13 AM Reply With Quote
Engine managment
I have a 1.8L zetec on bike carbs currently running on an old zetec ECU and loom, what is the best managment system for its money? I have been looking at omex and just wondered what everyone else uses and how much they cost?
Any advise is welcomed as I don't want to spend a million pounds on the wrong one.
michael92
posted on 7/1/13 at 11:17 AM Reply With Quote
morning!
I would put my money with megasquirt like i have. you can either build it yourself which obviously is cheaper or you can buy built ones. and you can tailor it to suit yours as such for fraction of the price! also these zetec engine loads have mapped them so there is plenty of help out there and base maps to make it easier
Michael
Charlie_Zetec
posted on 7/1/13 at 11:22 AM Reply With Quote
Originally posted by michael92
morning!
Michael
Surely if he's running carbs he only needs a Megajolt rather than a Megasquirt?
Dooey99
posted on 7/1/13 at 11:23 AM Reply With Quote
Yooooo
Can these run on carbs?
Lyle
michael92
posted on 7/1/13 at 11:26 AM Reply With Quote
sorry yeah didn't read you were running just on carbs, megajolt it is then
michael
blakep82
posted on 7/1/13 at 11:30 AM Reply With Quote
You sure its bike carbs and not bike throttle bodies? Wouldnt have thought the zetec ecu would work with carbs? I thought the zetec ecu did fuel injection and ignition?
'Jolt (or the new nodiz system, search on here for it) for carbs
'Squirt for throttle bodies and injection
________________________
Dooey99
posted on 7/1/13 at 11:38 AM Reply With Quote
Can I put a MAP sensor on bike carbs? They are carbs I'm not 100% what the ECU and loom is off but all the banger boys that run a zetec with a carb use it I heard it was the first ever zetec engine but I'm not sure
Megajolt it is then!
RichardK
posted on 7/1/13 at 12:00 PM Reply With Quote
TPS sensor would be easies with bike carbs imho
Megajolt is great.
Rich
Gallery updated 11/01/2011
snapper
posted on 7/1/13 at 12:27 PM Reply With Quote
MAP needs 4 individual vac take offs 1 from each inlet runner after the carb
TPS is on the throttle butterfly shaft
I eat to survive
I drink to forget
Mikef
posted on 7/1/13 at 01:36 PM Reply With Quote
I have been looking at Megajolt and Nodiz, I would have to say the Nodiz product does have a lot of features going for it, and they are very helpful. might be worth a look.
Nivek4209
posted on 27/3/13 at 09:59 PM Reply With Quote
Anyone running a 700 series omex
Kevin
dave_424
posted on 27/3/13 at 10:24 PM Reply With Quote
I would suggest megasquirt/megajolt.
Might be worth going with megasquirt so you have the option of adding fuel injection if you wanted.
There is a massive amount of people out there using it and the amount of information on the internet about it is unbelievable, lots of forums dedicated to this ECU.
Dave
Nivek4209
posted on 27/3/13 at 10:45 PM Reply With Quote
This will have to run ign and injection on a Honda vtec v6
And at some stage later I'd love to turbo it if the std internals would cope with a little boost well actually two little boosts being a v it would be easier to mount 2 smaller blowers
Kevin
dave_424
posted on 27/3/13 at 10:48 PM Reply With Quote
An MS1 v3.0 would do all this and more, a MS2 v3.0 would give better RPM resolution in the tables and a larger table size, with some settings trickery you can get 16x32 tables.
Dave
Nivek4209
posted on 27/3/13 at 10:59 PM Reply With Quote
I will go have a google now I always thought they were at the simpler end of things
Good stuff cheers
Kevin
Worzey
posted on 28/3/13 at 09:04 AM Reply With Quote
I'll have an OMEX 500 ECU with loom for sale as I've just upgraded to a 600 with my Supercharger upgrade. Should be available in about 2 weeks time if you're interested?
Caterham R400
Norfolkluegojnr
posted on 28/3/13 at 09:16 AM Reply With Quote
i'd go with Megajolt. Super easy to map, and lots of advice and help available on the forums.
Think i've mentioned before i'm just down the road from you - if you want a hand i've fitted Megajolt to two different zetec kit cars.
