Author: Subject: Electric water pump!?
Twin40
posted on 10/1/13 at 07:43 AM Reply With Quote
Hey guys,
I'm trying to find a way of properly mounting my Davies Craig water pump onto the Mk. Anybody here got any pictures of their build? Or know of a pre-made kit for these pumps?
Was going to make a bracket to suit the 4 bolts that hold the pump together, wasn't sure if this was a good idea?
Clive.
otodb
posted on 10/1/13 at 09:43 AM Reply With Quote
HI,
Mate of mine has a supercharged MGB & after fitting the hoses the pump was pretty secure so he adjusted the hose fit till the pump was just touching the S/C & then cable tied it to the S/C. He has done 4 track days & plenty of road miles with it like that & all is still fine.
All the best, Brian.
Twin40
posted on 10/1/13 at 12:55 PM Reply With Quote
Cheers brian, maybe i'll get the pipework first and see how it goes.
blakep82
posted on 10/1/13 at 03:27 PM Reply With Quote
I would mybe look at a bracket that holds the ends of the pipe, with rubber p clips perhaps.
Wouldn't use the screws that hold the pump together personally
________________________
Twin40
posted on 10/1/13 at 03:38 PM Reply With Quote
no i didn't really want to mess about with the pump bolts, bound to break it!!
T66
posted on 13/1/13 at 01:09 PM Reply With Quote
Mine was missing the original fittings (EWP) , so I made small L shaped brackets and drilled them, then slipped M6 setcrews into the plastic channels, the heads just fit nice and snug.
