Author: Subject: Alloy Fuel Tank Fabricator
prelude1980
posted on 12/1/13 at 10:18 PM Reply With Quote
i'm after someone that migh be able to fabricate a fuel tank for me,
I'm after the following
270mm high x 170mm wide x 720mm long
50mm inlet tube
50mm deep sump in the centre
baffled
3/8" inlet and outlet
1/2" Breather
2 x tank straps
I already have a vertical float fuel sender so the baffles can't interfere with it,
Thanks in advance
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
Ben_Copeland
posted on 12/1/13 at 10:25 PM Reply With Quote
Alloy racing fabrications. Makes very nice tanks and reasonably price too
Ben
Locost Map on Google Maps
Enter Your Details Here
prelude1980
posted on 12/1/13 at 10:26 PM Reply With Quote
funnily enough just waiting for their price on this
gets you.
Ben_Copeland
posted on 12/1/13 at 10:32 PM Reply With Quote
Fuel Tank
Fuel Tank
That's mine
Ben
prelude1980
posted on 12/1/13 at 10:33 PM Reply With Quote
Looks just like i need, just with the inlet at one end.
Do you know how thick the ally is on them?
gets you.
Ben_Copeland
posted on 12/1/13 at 11:09 PM Reply With Quote
Not sure on the thickness but you can have any configuration you like.
The swage lines make the sides stiff and its baffled and sumped
Ben
40inches
posted on 12/1/13 at 11:24 PM Reply With Quote
Try Bryn Jones
theprisioner
posted on 12/1/13 at 11:36 PM Reply With Quote
Another vote for Bryn Jones
ashg
posted on 13/1/13 at 12:27 AM Reply With Quote
martin keenan will make you one if you send him an email, i have not seen anyone more natural at welding ali
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
TimC
posted on 13/1/13 at 09:20 AM Reply With Quote
This is Martin's work:
big-vee-twin
posted on 13/1/13 at 09:27 AM Reply With Quote
Another alloy racing fabs vote
[img] Fuel Tank In
Fuel Tank In
[/img]
http://www.triangleltd.com
big_l
posted on 13/1/13 at 01:34 PM Reply With Quote
Alloy racing fabrications are the Bollox
Check out my blog mnrvortxhayabusa@blogspot.com
prelude1980
posted on 13/1/13 at 03:10 PM Reply With Quote
I'll give Bryn Jones and Martin Keenan a try
gets you.
Benzo
posted on 14/1/13 at 06:02 PM Reply With Quote
If you dont mind me asking, where did you get the vertical float sender? Is this like a dip tube sender?
[Edited on 14/1/13 by Benzo]
number-1
posted on 14/1/13 at 06:08 PM Reply With Quote
Give Bob a shout...the guys a genius! Look at the bodywork on my kit car....all hand made by him Conceptracing
[Edited on 14/1/13 by number-1]
prelude1980
posted on 14/1/13 at 07:15 PM Reply With Quote
it was from a marine supplier used in either fuel/water tanks
Bit like linky
i wanted this as it suited my Acewell dash better
gets you.
