Author: Subject: 4age clocks wiring
makoto
posted on 23/1/13 at 02:27 PM Reply With Quote
4age clocks wiring
Hi Folks,
I am in the process to wire to my clocks on the kitcar, but I am abit stuck on the wiring. Ive identified and wired some already but there are a few which I am not sure of. Below are a list of the wires. Can some please point me in the right direction as to what goes where.
From left to right –
Fuel W :
IGN+ :
Cooling fan : Connected
ED.SW :
IGN - :
ILM – :
ILM+:
RS:
SP: Speed signal – connected
BEAM:
TURNING (L) - indicators wired
TURNING(R) - indicators wired
OIL.U - wired
GAUGE
TEMP.U :
CHG – :
BRAKE
CHG +
CHECK : Check engine light - connected
HAZARD : Hazards
deezee
posted on 23/1/13 at 05:28 PM Reply With Quote
It would help to know the clocks you are using? Are they after market or off a donor?
makoto
posted on 23/1/13 at 05:36 PM Reply With Quote
It is the standard 4age(donor) clocks
deezee
posted on 23/1/13 at 06:41 PM Reply With Quote
? The 4AGE is the engine. The clocks varied in every car? The Celica, Corolla or MR2. All different clocks. I have manuals for a few. Just thought i could help if i knew the donor.
makoto
posted on 23/1/13 at 07:35 PM Reply With Quote
Hi, sorry...I meant to include MR2 MK1b. Not helping myself here...
deezee
posted on 23/1/13 at 08:21 PM Reply With Quote
OK cool, You can find the Workshop Manual PDF Here. Under section BE-24 Body Electrical system has a pin out guide and a wiring diagram. I hope this helps.
makoto
posted on 23/1/13 at 09:41 PM Reply With Quote
thanks, much appreciated
