Author: Subject: TRansit Connect Immobiliser fault help please.
macc man
posted on 11/2/13 at 07:51 PM Reply With Quote
Has anyone had any experience of an immobiliser fault on a connect van. When I turn the ignition on I get a rapid flashing light on the dash and the van will not turn over. Seems to be an intermittent fault. Had the local garage out but were unable to read the fault codes. I need it for work so any help would be appreciated.Thanks.
doddy
posted on 11/2/13 at 08:16 PM Reply With Quote
i dont no the answer i use this forum when ever i have a problem and i alway get the answers in need
http://fordtransit.org/forum/index.php?sid=aae5cefea4f2d97a055fe3f3a2ba7d3f
https://www.ebay.co.uk/str/4x4wheels
macc man
posted on 11/2/13 at 09:07 PM Reply With Quote
I just went outside to have a play around with the fuse box. When I swapped the ignition relay it started! Thanks for the advice I found the Transit forum a mine of information. I will get a new relay in the morning if it still goes. Fingers crossed.
GOJO
posted on 11/2/13 at 09:13 PM Reply With Quote
Battery terminal , there prone for a poor connection (corrosion) causing low voltage to ecu etc.
