Disgruntled karter
posted on 15/2/13 at 09:09 AM |
paneling Locost
I'm just about to start panelling my Locost and I have a question
At the moment the chassis is in etch primer, once I've finished fettling and pre drilling the Ali panels I'm planning to spray the chassis
with POR chassis black. (got the proper mask and will be leaving the garage doors and windows open!)
My question is, is it worth me pre drilling the chassis (using the ali panels as a template) and then spraying the chassis so I get a coat of paint
on the inside of the rivet holes, or should I just spray the chassis and then drill it for the panels.
I'm using sealed rivets and will be bonding the panels as well.
Thanks Graham
Slimy38
posted on 15/2/13 at 09:20 AM |
I'll be using a squirt of waxoyl for any 'internal' protection.
sdh2903
posted on 15/2/13 at 09:24 AM |
Bonding/riveting should be fine, after all the inside of the chassis tubes will still be bare metal even if you paint the drilled holes. Also if you
paint the holes your rivets may not fit and you end up clearing the holes out anyway.
mcerd1
posted on 15/2/13 at 09:41 AM |
+1
also any swarf that falls inside the tube will get stuck in it and not rattle around
a good bead of PU adhesive between the panels and chassis should be more than enough to seal it up - just make sure you remove any paint and key the
surfaces from the areas where the PU is to bond to
even if you paint the chassis before paneling it shoukld still be fine
(although painting /sealing over the rivet heads afterwards won't hurt!)
[Edited on 15/2/2013 by mcerd1]
ceebmoj
posted on 15/2/13 at 09:46 AM |
+1
Youer hearing is far better than mine if you can hear the swarf rattling. and a couple of drives im sure will degrade youer hearing to the point that
is no no longer an issue. ;-)
RK
posted on 15/2/13 at 01:04 PM |
Your dog could not hear any swarf inside the chassis, even if your car is electric.
loggyboy
posted on 15/2/13 at 01:09 PM |
Just to 2nd/3rd/4th the waxoyl suggestion..
Mistral Motorsport
