greenwood03
| posted on 15/2/13 at 11:23 AM |
extinguisher, springs,rack,clutch quadrant,grovved pulleys
yep bit of a clear out: all items located 10 mins south of Dartford Crossing, 10 mins from sevenoaks, 5 mins Brands Hatch, can post if required.
Plumbed in extinguisher, 3.5kg, you can see its out of date for racing - so needs a re-charge to comply with msa regs. 2 pull handles and 2 nozzles.
clutch quadrant sierra, pcqo4, brand new still in sealed bag £7
2x 300 lb x 9 inch springs, clearly not new! ( came off my old tiger supercat rear) £15
sierra steering column with key £30
2x 275lb x 10.5 inch springs, fitted and realised that they were wrong, so in reality as close to brand new as you can get.
2 grooved pulleys 55mm(15mm) / 85mm (17mm) £12 the pair
shortened propshaft. came off my tiger supercat, knuckle to knuckle 30.5 inches to within a fraction, can measure exactly if required. prop was
refurbed and rebalanced in 2011. £25
also battery isolater switch with 1 key. £5
http://southernkitcars.comIntermarque Club for owners in the South/South East
olimarler
| posted on 15/2/13 at 11:41 AM |
Hi mate,
How much for the extinguisher?
Oli
greenwood03
| posted on 15/2/13 at 12:48 PM |
Oli, sent you a u2u
pekwah1
| posted on 15/2/13 at 02:24 PM |
where's the rack then?
loggyboy
| posted on 15/2/13 at 02:30 PM |
Are the pulleys idlers with bearings? or just plain bolt on jobs?
Interested if the bearing'd variety.
Mistral Motorsport
rodgling
| posted on 15/2/13 at 02:33 PM |
Will take the 300 lb springs if they are 2.25" ID
greenwood03
| posted on 15/2/13 at 03:19 PM |
rodgling - reply sent.
loggy - sorry just plain bolt on
pekwah.....bugger, between thinking about work and typing the ad i screwed up, didnt mean 'rack', meant steering column - doh......
greenwood03
| posted on 18/2/13 at 10:46 AM |
following items now sold: prop, pulleys, extinguisher, 300lb springs.....
the other bits are still available.
