Author: Subject: Garage Clearout
deeceee09
posted on 24/2/13 at 05:53 PM Reply With Quote
Garage Clearout
13” inner rims, 5” overall, 4.625” to tyre bead, 18 x 6.1mm dia holes on PCD of 10.5”, centre bore 9.8”
1 pair Image good condition £100
1 pair Superlite serviceable £75
ST150 starter motor £20
Dunnell (ITG?) unused foam air filter 130 mm deep and back plate to suit twin DCOEs on 2 li Zetec £45
Set of 4 injectors 280 150 749. Hardly used since cleaned and tested, flow rate 225 cc/min £100
Cam position sensor for 2 li Duratec £10
Standard hydraulic clutch release to suit MTX75 box and 2 li Duratec £20
Treachery and old age will always triumph over youthful enthusiasm.
warboys
posted on 27/2/13 at 01:16 PM Reply With Quote
U2U sent
