andrew-theasby
| posted on 27/2/13 at 09:46 PM |
Hub nut threads, which way round?
Just looked at my hub nuts today and I think I have them the wrong way round, could anyone please confirm which side should have the left hand thread?
Ps sierra rear hubs btw. If I've got it wrong is it worth changing or will split pinning or wire locking be ok? It's only vibration
that's acting on it, the shafts are splined so nothing can turn. Thanks
adithorp
| posted on 27/2/13 at 09:55 PM |
Left-hand thread on the left, right-hand on the right.
I'd swap them to the correct side; It isn't just vibration either.
http://jpsc.org.uk/forum/
austin man
| posted on 27/2/13 at 10:00 PM |
I thought the shafts were different lengths so getting the mixed up shouldnt happen the lef hand thread i would think is offside rear
mark chandler
| posted on 27/2/13 at 10:18 PM |
The shafts are different lengths, unless you split them and put the wrong outers on you should be fine.
I believe very late ones were right hand thread both sides so nothing to stress about really as they get done up very tightly.
andrew-theasby
| posted on 27/2/13 at 10:39 PM |
Hmmm two opposite answers and one saying it doesn't matter unfortunately I can't go by the shafts as these are completely stripped
down to bare parts at the mo, but I'm tempted to agree that I don't think it really matters either (read as "less work that
way" )
| posted on 27/2/13 at 11:21 PM |
Near side left hand, off side right hand and the shafts are different lengths so you can put them side by side and compare. Nearside is shorter.
loggyboy
| posted on 28/2/13 at 12:10 AM |
Quite simple, the wheel on the left mostly turns anti clockwise so it should have the reversed thread, so the natural turning of the wheel wont
loosen it.
Mistral Motorsport
jonabonospen
| posted on 28/2/13 at 12:13 AM |
Just learnt this in my build this week. Left thread on the left side (when looking from the back of the car - so nearside), and right thread on the
right / off side.
MAC#1 ZX10R WORX BUILD BLOG: http://mac1-zx10r-worx-build-blog.tumblr.com/
MY PERSONAL BLOG: http://jonabonospen.tumblr.com/
andrew-theasby
| posted on 28/2/13 at 12:33 AM |
I should have had a vote on this, left hand thread on the left is just winning at the mo, which is how i have it, but as for the direction of
rotation, why does that matter, the wheel can't slip relative to the shaft, it's splined!
TAZZMAXX
| posted on 28/2/13 at 07:59 AM |
A bit of reading matter on the subject http://www.boltscience.com/pages/failure4.htm
| posted on 28/2/13 at 08:42 AM |
Nuts should tighten in the normal direction of rotation of the wheel.
loggyboy
| posted on 28/2/13 at 09:25 AM |
Thats wheel bolts/nuts, not hub nuts?
Mistral Motorsport
loggyboy
| posted on 28/2/13 at 09:41 AM |
OOO this makes for some interested reading... After googling this subject, it does indeed seem to be a 50/50 split on who thinks left thread on left
side or left thread on right side. Whilst the argument I made earlier about the natural movement of the wheel seems to make more sence, the acctual
science is alot more complicated. The best/most reliable explanation I can find is here:
http://blog.everydayscientist.com/?p=2655
Mistral Motorsport
wilkingj
| posted on 28/2/13 at 09:55 AM |
This is a good reason for only dismantling one shaft at a time!
Best Regards
Geoff
http://www.v8viento.co.uk
loggyboy
| posted on 28/2/13 at 10:06 AM |
As long has they havent been dismantled before and put back wrong!!
Mistral Motorsport
| posted on 28/2/13 at 03:48 PM |
There should be no argument at all, left hand thread is for wheels turning anti-clockwise. I drew this picture ages ago to explain this on LCB:
Effectively the problem is an eccentric loading pattern as your link shows, but on a CV joint the load point that moves is between the hub and the
flat clamping surface of the nut. Obviously the drawing is grossly exaggerated, but you can see how the clamping load would be greater at one point
on the nut as the hub gets loaded by the weight of the car. Since the wheel is rotating, this load point also rotates but at a faster rate than the
nut due to the eccentric movement.
This is also why you have to torque up hub nuts to very high values to preload everything.
[Edited on 28/2/13 by MikeRJ]
| posted on 28/2/13 at 04:22 PM |
Correct, it's not really a discussion it's a statement of fact
Canada EH!
| posted on 28/2/13 at 04:27 PM |
Chrysler products in North America had left hand threads on the left side (drivers side over here) and right hand threads on the right or passenger
side.
This lasted until the late 60's when garage men (Ford and GM) who were not familiar with this kept breaking the wheel studs with the newly
introduced impact guns.
