CNHSS1
posted on 20/3/13 at 07:59 PM |
pair usable sierra rear calipers
im looking for a pair of sierra rear calipers for solid discs or equivalent.
dont need to be flash, but must be usable and complete. To fit westfield uprighst with 240mm discs
what have you got?
CNHSS1
posted on 21/3/13 at 10:00 PM |
bump
nobby_the_sheep
posted on 22/3/13 at 08:39 AM |
I've got a pair of VW Golf rear calipers if they're any use to you?
I think Westfield may use these too..... might fit ok?
CNHSS1
posted on 22/3/13 at 03:49 PM |
i have the VAG ones but the slider mounting offset is different, so id need either bigger discs or the westfield VW version of the uprights.
dont fancy flogging the uprights i have to fit the calipers ive got, so just wanted some boggo sierra ones that fit with 240mm discs.
should say that the trouble is that im using 13" rims, if i was using 15s id just use bigger discs and the VAG calipers i have
thanks for the offer though :-)
CNHSS1
posted on 23/3/13 at 02:14 PM |
sorted now thanks to Andy from AB Performance :-)
scimjim
posted on 24/3/13 at 11:36 PM |
you didn't buy one of his G2 Sabres as well did you? :-)
CNHSS1
posted on 24/3/13 at 11:40 PM |
not yet Jim, cracking bit of kit though
