Author: Subject: megasquirt tps
roohunter
posted on 30/3/13 at 01:06 PM Reply With Quote
megasquirt tps
Hi folks
Could anyone tell me which colour wire goes to which pin on the tps , black top zetec , megasquirt v1, single plenum with zetec throttle body.
Thanks folks
r1_pete
posted on 30/3/13 at 01:16 PM Reply With Quote
If you have an ohm meter, find the two connections whose resistance doesn't change, these are the outer two in the pic below.
The one which increases / decreases when connected to either of the others is the wiper, from there you can work out which needs to be reference voltage, negative, and wiper.
