cps13
posted on 8/4/13 at 06:34 PM |
Sierra handbrake cable to MK Indy
Am I missing something, I cannot figure out how to get my handbrake cable into the chassis! The ends to hook onto the calipers are crimped on and the
plastic screw bits to hold it in place will obviously not fit through the tubes just above the tunnel so I cannot thread it through. Am I being
stupid. Picture below to try and illustrate, this is not my build but helps to show what i'm on about.
[Edited on 8/4/13 by cps13]
40inches
posted on 8/4/13 at 06:45 PM |
You have to cut the inner cable, then rejoin it using wire rope splicing clamps. I'll see if I can find a photo.
There you go.
![](/galpreviews/DSCI0623.JPG) ![Description](/gallery/DSCI0623.JPG) Description
![](/galpreviews/DSCI1064.JPG) ![Description](/gallery/DSCI1064.JPG) Description
![](/galpreviews/DSCI1072.JPG) ![Description](/gallery/DSCI1072.JPG) Description
[Edited on 8-4-13 by 40inches]
ReMan
posted on 8/4/13 at 06:57 PM |
That's not what I did!
but I'm fooked if I can remember what I did do!!
www.plusnine.co.uk
40inches
posted on 8/4/13 at 07:02 PM |
You must be older than me!
yellowcab
posted on 8/4/13 at 07:08 PM |
he is pretty ancient to be fair...
cps13
Thanks!! I have some of those left over from the boat steering! For once something goes my way ![](/images//smilies/smile.gif)
Sloan85
posted on 8/4/13 at 07:22 PM |
I cut off one end and used a temporary repair end with grub screws in which I got from MK.
Other photos show how I cut back one of the handbrake outer cable ends to fix it through the chassis with a washer that I cut a slot out of.
Outer cable end - before
Outer cable end - after + washer
In position
![](http://i1051.photobucket.com/albums/s438/james_sloan85/MK%20Indy%20Build/IMG_0149_zps8965b254.jpg)
40inches
posted on 8/4/13 at 08:23 PM |
So by definition, so am I ?????? thanks mate!
40inches
posted on 8/4/13 at 08:26 PM |
Snap! See, boats aren't just a hole in the water you pour money into, after all.
ReMan
posted on 8/4/13 at 08:34 PM |
I've just remembered
I used a screw on end like the one pictured
Where's me puddin'!
www.plusnine.co.uk
40inches
posted on 8/4/13 at 08:39 PM |
Where's me puddin'!
I think it's next to your pipe and slippers.
