mike2704
posted on 12/4/13 at 11:46 PM |
type 9 5 speed
Hi, I'm looking for a fairly cheap type 9 5 speed gearbox for my 1600 x flow as I guess loads of people are,
I thought I would ask on here as there might be a fellow locoster with one tucked away somewhere.
I have the chance of a sierra mt75 but it looks so much larger than the type 9 and a lot more mods would be needed I should think so advice as well
would be gratefully received.
Thanks Mike
cps13
posted on 13/4/13 at 07:33 PM |
I am in southampton too and I have a partial type 9. It has been taken apart in the middle, needs bolting back together and would suggest getting it
checked out at a gearbox place but its an option if you want in.
£35 due to condition.
mike2704
posted on 14/4/13 at 12:49 PM |
type 9 5 speed
Hi do you know if any bits missing and what condition most of the parts are in.
cheers Mike
cps13
posted on 14/4/13 at 04:04 PM |
cheers Mike
Nothing is missing I don't think. I've had the top plate off to check the condition. All the gears look clean and good.
Jimfin
posted on 16/4/13 at 07:37 AM |
Mike - cannot help with parts but I swapped the standard Escort 4 speed for a type 9 a few years ago and can offer advice. Main issue is that the type
9 is 110mm longer and you need a new/altered prop shaft both shorter and different output shaft splines. The gearbox centre mounting is in a different
position and I needed a new plate to support it but no other chassis mods. Westfield do a proper mount for it from their spares section. You need a
clutch plate from a Sierra 1600 as the splines are right for the type 9 input shaft but it is the same diameter as the Escort so keep the Escort
cover. If you have a mechanical speedo - need a 90 degree for the output.
mike2704
posted on 19/4/13 at 04:56 PM |
Thanks for all the input I think I will have to wait a while before I decide what to do, finances and time being the major factors.
cp13 I could give £30 for your gearbox just so I could play with it. Overhaul kits cost a fortune.
Thanks again Mike
scimjim
posted on 19/4/13 at 11:06 PM |
U2U sent last Monday.
cps13
posted on 19/4/13 at 11:48 PM |
Both boxes are provisionally sold.
cps13
posted on 19/4/13 at 11:49 PM |
I looked thru my inbox and cannot see a U2U from you.
scimjim
posted on 20/4/13 at 07:33 AM |
U2U sent to Mike.
posted on 4/5/13 at 09:31 PM |
Hi mike do you still need a type 9 box taking mine out soon. If your interested let me know.
