fha772
posted on 14/4/13 at 11:27 PM |
Any solar panel battery charger experts here?
Hi all,
I'm looking for a 24v solar panel battery charger/maintainer, for my 7.5 tonner.
It doesn't have to be big amperage, it's only to just keep the batteries topped up, when the lorry is stood.
I can't use an isolator switch as I'm fitting 2 alarm systems to it (1 in the cab, and 1 in the box body), so the batteries need to be
switched on, when I park it up.
Has anyone got any experience with this sort of stuff?
What would you recommend?
What parts do I need?
Cheers Frank.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
inkafone
posted on 14/4/13 at 11:50 PM |
A 24v solar panel is expensive but two 12v ones in series aren't. Just fit as per the instructions they come with only wire them in series on
one plug.
4 Watt 12v Volt Solar Panel Trickle Car Battery Charger Boat | eBay![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
steve m
posted on 15/4/13 at 08:12 AM |
I use a 12v solar panel for the 7, and also for my caravan, so buying 2 x 12v will be a better option in the end
as for disableing the van, why not locate, and pull out the fuel pump relay, for security ?
Slimy38
posted on 15/4/13 at 08:22 AM |
That stops the van from going anywhere, doesn't stop the contents though...
Ninehigh
posted on 15/4/13 at 09:55 AM |
Neither would cutting the battery.. Heck the only thing stopping the contents is them being somewhere else
Would 2 panels in series really work like that? I'd imagine that 12v going into the negative terminal of the second panel wouldn't
increase anything
coyoteboy
posted on 15/4/13 at 07:43 PM |
Yes, solar cell strings work in series as well as parallel, but there are complications if one is likely to be shaded when the other is in light etc.
If they're set together in the same light source without shading you can approximate them as a single 24v panel with the same current rating as
the 12v but twice the voltage (and hence twice the power output). That's assuming there's no control circuitry in the way and it's
just the old dumb panel setup as most are.
[Edited on 15/4/13 by coyoteboy]
jacko
posted on 15/4/13 at 08:35 PM |
http://midsummerenergy.co.uk/solar-panel-information/Guides/Narrowboats
have a look at the solar panels on narrow boats
Jacko
