Author: Subject: Welder Problem
mikeb
posted on 15/4/13 at 02:14 PM Reply With Quote
Welder Problem
I have a Boc Migmate 130, think its the pretty standard hobby mig with the min max 1 and 2 setting and wire feed dial.
It use to be a good welder producing nice welds but its slowly started playing up. I'd finished my chassis so only used it for the odd small job.
I thought it was a earth issue so put a new earth clamp and wire on it.
It no longer produces the nice frying bacon noise, if I can get a weld out of it at all, it seems to be creating a weld pool from the feed wire but not penertrating enough often ending up with a lump stuck to the tip. Most of the time now it pops and spits back at me, every now and again I'll get a good weld for 15 seconds but only on a good day!
the wire feed seems good, well its fine when I'm not actually welding.
I'm still wondering if its a powersupply/earth issue.
I've put new tips on (haven't changed the shroud) I did check inside for any loose connections etc. Can you get a live shround
Any thoughts,
r1_pete
posted on 15/4/13 at 02:21 PM Reply With Quote
Have you checked the wire liner, the standard nylon ones do degrade over time and cause the welding wire to drag.
Replacing it with a steel liner, often transforms the machine, and not expensive..
mikeb
posted on 15/4/13 at 03:23 PM Reply With Quote
the wire feed seems good and smooth
Slimy38
posted on 15/4/13 at 04:13 PM Reply With Quote
This might seem a little off topic, but I took a look at steel liners after reading this, and a cost effective option seems to be curtain wire. Did I miss something in the translation, or is curtain wire a viable solution?
r1_pete
posted on 15/4/13 at 04:35 PM Reply With Quote
Yes I have read that too, never tried it, doubt I would to save a few ££, Id go with the purpose made thing.
theprisioner
posted on 15/4/13 at 06:23 PM Reply With Quote
Is it a gas or gas-less system you are using cos it sound like a gas problem to me. If I turn my gas off I get exactly the symptoms you describe.
Staple balls
posted on 15/4/13 at 07:21 PM Reply With Quote
I'm sure curtain wire would work, or bike brake outer, but saying that, I got a 3m liner off ebay for a couple of quid, took a little fettling to make it fit my machine, but utterly transformed it for next to no money.
LoMoss
posted on 15/4/13 at 08:44 PM Reply With Quote
Have you changed the tip. They fug up with dirt from the wire and welding?
HTH
Moss
