Author: Subject: NODIZ Pinto Package Released and 10% discount!
mtechmatt
posted on 8/5/13 at 09:05 AM Reply With Quote
If you are looking to go electronic ignition on your pinto, we now offer a full NODIZ Pinto conversion kit.
It includes trigger wheel, sensor and bracketry, coil pack, leads and NODIZ Pro system...
Available from our site here:
http://nodiz.co.uk/nodizpro-shop.html
The first 3 orders from Locost (please PM me) will get a 10% discount!
Any questions fire away, and we will be putting a step by step install guide up shortly
Matt
V4 Engine Management System | Online Shop | Rolling Road Tuning | Motorsport Preparation | Engine Packages | Throttle Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
Confused but excited.
posted on 8/5/13 at 09:49 AM Reply With Quote
Have you considered registering as a Trader?
chrisxr2
posted on 8/5/13 at 09:50 AM Reply With Quote
May seem obvious
Might seem like an obvious question, but what real advantage does this have over the distributor setup??
Life moves pretty fast, if you don't stop and look around once in a while, you could miss it.
mtechmatt
posted on 8/5/13 at 10:38 AM Reply With Quote
We were traders, not sure why it has gone from our status?
The advantage is it removes points, which stops all sorts of problems, delivers a stronger spark at much more accurate timings.
Have a look here, for a dizz/nodiz comparison... 13bhp
Matt
The Workshop
johnemms
posted on 8/5/13 at 10:46 AM Reply With Quote
If you change anything from the standard engine ie:
pistons - compression - cams etc.. also remember the curve is for a very heavy car and four people..
Your distributor ignition curve will no longer match your engine specs.
Worst case is blow up your engine - typical is low power
Hence - a programmable ignition unit which you then have mapped on a rolling road to suit your car.
Safe maximum performance from your bespoke engine and chassis. Also changeable cranking advance for easy starting on high compression & aggressive cams !!
[Edited on 8/5/13 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
mtechmatt
posted on 8/5/13 at 11:06 AM Reply With Quote
Well said that man...
The Workshop
