daniel mason
posted on 13/5/13 at 07:31 PM |
can someone recommend me a decent battery
my battery is still losing charge and struggled to start the fury if not fully charged so can anyone recommend a decent lightweight battery which will
be good enough to start the 919 blade motor? cheers
cerbera
posted on 13/5/13 at 07:35 PM |
The ones Russbost sells are certainly lightweight.
Linky doo dah
big_l
posted on 13/5/13 at 07:41 PM |
Odessey 25 is the bollox starts the Busa well easy
Merlin Motorsport is the cheapest
Check out my blog mnrvortxhayabusa@blogspot.com
daniel mason
posted on 13/5/13 at 07:52 PM |
how good are the lithium ones? any dis advantages?
matt_gsxr
posted on 13/5/13 at 08:07 PM |
I'd worry about this new technology in a fibreglass car (Boeing Dreamliner?).
Odyssey pc680 works well for me.
perksy
posted on 13/5/13 at 08:16 PM |
Another vote for the Odyssey PC680.
Last time i looked there was a Bike shop up in Yorkshire that was the cheapest and i found them using Google.
posted on 13/5/13 at 08:21 PM |
I used a red top 25 on my zetec that was specced for a buell 1200.
russbost
posted on 13/5/13 at 08:28 PM |
I can match prices with the Odyssey range in terms of cranking power etc. & the Li Ion batteries are around 5 - 15kg lighter depending what spec
you're looking at. The only way they will catch fire is if you set fire to the casing - not the same technology as the dreamliner batteries,
TTBOMK there are no disadvantages in terms of use on a kitcar & many, many advantages
daniel mason
posted on 13/5/13 at 08:32 PM |
what would you recommend for a bec russ? and do you do an alloy battery box for them? cheers
mark chandler
posted on 13/5/13 at 09:03 PM |
Just a thought, blade regulators are rubbish and the standard spade connectors continually overheat, are you sure your charging circuit is good?
daniel mason
posted on 13/5/13 at 09:31 PM |
i think so mark. the builder was absolutely meticulous and the regulater is mounted directly under a small fan that runs as soon as ignition is
pressed. it runs relaively cool to be honest
[Edited on 13/5/13 by daniel mason]
russbost
posted on 14/5/13 at 09:49 AM |
Hi Daniel
Recommended battery for the 919 blade is our part no. Lip010B, £136.99 normally I can do 10% off if we're dealing direct so £123.29 & £7.95
P & P. That's about a tenner more than a redtop 25 & over 5Kg lighter - I reckon you'd save the tenner in fuel over a years use!
Cheers Russ
posted on 14/5/13 at 09:50 AM |
Have to say from your other post and this that there must be a question over charging. Can you swap the battery with a known good one to test and
maybe fit the one from the kit in another vehicle to double test?
