Author: Subject: IVA Pre check Help in Yorkshire
daveb666
posted on 20/5/13 at 01:50 PM Reply With Quote
Hi, just taken collected the built Locost of big_wasa. There are a couple of things I know I need to do for the IVA (oil breather to catch tank and wrap lambda sensor) but I just wondered if there is anyone in the Yorkshire (Huddersfield area) that would have half an hour to spend to take a look over the car since I've missed anything.
THanks in advance
johnemms
posted on 20/5/13 at 02:18 PM Reply With Quote
The way i did it was...
If you see 'anything' that even looks remotely suspicious.
Evostik & Edging trim - rubber over nuts etc anything that can be covered .. just cover it,,
Remember .. a mechanic should be able to replace protective trim. Though Cable ties seem disposable..
Just keep looking and covering every edge !!
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
Ben_Copeland
posted on 20/5/13 at 03:02 PM Reply With Quote
Stick a load of pictures up from different angles. People will spot things!!
Ben
Locost Map on Google Maps
Enter Your Details Here
Jimfin
posted on 21/5/13 at 08:18 AM Reply With Quote
2 suggestions - assuming you can move the car -
1) Get a local garage to check the car to MOT standard, the 3 thinks you really need (as they require specialist kit) are emissions, brake function and percentages for service and handbrake and headlight alignment. It was this point I discovered that the headlights bought at a kit car show had left hand drive lenses!
2) Given your location, I would speak to Chris / Mark at MNR. Mark did a check for me, pointed out some details that needed attention in exchange for a modest fee. They fitted me in at a quiet time for them and spent about 45 mins going over it.
Those steps helped me get through first time.
pif
posted on 21/5/13 at 10:07 AM Reply With Quote
Mark at Mac1 did my pre check and gave great advice.
Pif
been a bit of a rush job really, bodged it all together in just 5 1/2 years.
daveb666
posted on 21/5/13 at 10:10 AM Reply With Quote
I was hoping that I'd find someone to come to me as I have to hire a transporter to move the car I'll get some pictures up this week.
