Author: Subject: English axle LSD or diff
birdy7up
posted on 1/6/13 at 02:26 PM Reply With Quote
As a newbie to the forum I have an old locost requiring a rear axle rebuild including crown & pinion etc.
I have been advised to try and find a LSD but would consider good diff or complete english axle to fit Mk3/4 Cortina.
Any bits or advise greatly welcomed
posted on 1/6/13 at 03:06 PM Reply With Quote
No such thing as an english axle to fit a Mk3/4/5 Cortina.
In the Cortina the English axle ended with the MK2
watsonpj
posted on 1/6/13 at 07:05 PM Reply With Quote
So i guess the question is, is it an english (escort) axle or a cotina axle. Either post some pics or check if the diff comes out through the back or front. Front is english, back is cortina.
Pete
Aaron_n_Sim
posted on 1/6/13 at 07:16 PM Reply With Quote
Pete
Maybe me but English was used in all as was atlas they're all rwd no difference it's a transverse configuration either way! Both point to the front so confuses the chap asking the question!,like I say may have misunderstood not attempting to insult anyone!
Work to Live don't Live to Work
birdy7up
posted on 1/6/13 at 07:56 PM Reply With Quote
Hi all,
Thanks for replies,
I have removed the axle and is with the company rebuilding I will call on Monday to confirm if its english or not.
He did inform me when looking to source parts it was definitely mk 4/5 cortina.
Will update with further info on Monday
watsonpj
posted on 1/6/13 at 10:31 PM Reply With Quote
Aaron n Sim
no worries didn't want to confuse just thought its the easy way to tell if its english or atlas as there are few combinations of each at differing widths.
good luck with it birdy
Pete
birdy7up
posted on 4/6/13 at 08:18 PM Reply With Quote
Hi
I spoke to the man in the Know,
I have a an Atlas Axle, With gears removed from the rear
cheers
Trollyjack
posted on 5/6/13 at 11:30 AM Reply With Quote
Hi I have a English Axle case and also have a 3.89 dif to fit
The axle has been on a locost at some point needs drive shafts.
Wanting £100
TrollyJack
Jon Ison
posted on 16/6/13 at 02:52 PM Reply With Quote
Originally posted by birdy7up
Hi
cheers
Who's doing it for you, Tom not far from the crem ?
birdy7up
posted on 16/6/13 at 02:57 PM Reply With Quote
It's Neil at allgears in Worksop
