Author: Subject: Gear position sensor trouble
Custardpants
posted on 7/6/13 at 04:14 PM Reply With Quote
It seems my Busa engine has decided to stop showing third gear - both on the bike clocks and on my TRE. Are there any fixes to reset the Gear position sensor or anything else I can try before I have to take the clutch out to change the sensor? Wish they had designed it to be an easier fix! I'm also running a power commander - does anyone know how the healtech TRE affects the power commander map? (Wanted to know if that means I have no map in third gear). Many thanks!
bobinspain
posted on 9/6/13 at 10:39 AM Reply With Quote
Check u2u Luke.
