theconrodkid
posted on 21/6/13 at 06:54 PM |
washing machine noise
as you lot know everything , my machine is making a noise where the drum rubs on the seal,any ideas about lubricating it or is there another
reason/cure ?
who cares who wins
pass the pork pies
watsonpj
posted on 21/6/13 at 07:50 PM |
more likely the bearings on the way out thats what is was when ours did that.
joneh
posted on 21/6/13 at 07:52 PM |
Similar thing happened to me, with a cable tie poking in one of the drum holes, rubbing the around the drum. Must have left it the pocket...
on_eighty_runner
posted on 21/6/13 at 08:45 PM |
Had a hotpoint and there was a squeak which I was told required a grease between the door rubber gasket and drum. It was done under warranty twice but
seemed to be a bearing noise which never went away. Died 8 years later of a failed clock unit! Children's washing puts a huge load on a
machine
As previously mentioned could be a wire (or bra underwire) between drum and outer shell sounds quite bad. If you Cant see it in the drum is likely to
be stuck at bottom of drum where outlet connection is. It in an easy but wet fix! Have seen this a few times.
theconrodkid
posted on 22/6/13 at 05:15 AM |
the answer i didnt want to hear , it,s unlikley to be a bra as i dont wear one .
who cares who wins
pass the pork pies
Dave Ashurst
posted on 22/6/13 at 05:22 AM |
One of those rare moments when you wish you did
bob
posted on 22/6/13 at 06:11 AM |
How old is it John ?
More likely to be the bearings if at age, Mrs bob has just informed me John Lewis are no dearer than the usual suspects (curry's PC world) and
they also give you a 2 year warranty instead of one and will take your old machine away for free.
You could attempt a bearing change but to be honest combustion engines are easier !!
matt_gsxr
posted on 22/6/13 at 07:32 AM |
Are you suggesting he should make a Pinto powered washing machine.
posted on 22/6/13 at 12:46 PM |
When it comes to a new washer, I suggest getting one of the Siemens ones with a 5 year warrantee. Blinding value, mine was only about 450.
posted on 22/6/13 at 02:49 PM |
A pinto would struggle to wash a pair of socks and a bike engine would expire before the end of the wash. V8 is where it's at
Ninehigh
posted on 22/6/13 at 06:04 PM |
Win
Clarkson's probably got his washing machine powered with that Chevy v8
