Author: Subject: More brake pain - aaaaarrgggghhh!!!
Poorscousertommy
posted on 24/6/13 at 07:51 PM Reply With Quote
Hey folks. Looks like i'll be building this car one post at a time
So finally figured out how brakes work.. And then I ran into this issue:
The disc isnt yet bolted on, but I've swung on the hub nuts to be sure the hub and carrier are as tight as can be.
There isnt any learance between the disc and the inside of the carrier, they arent quite rubbing, but I'm sure the disc should be more central.
Any clues here? The calipers, mounts and disc all supplied by MK, so dont think thats the issue. Any cleas as to what I need to check? Note that both sides are the same so dont think its an assembly offset issue.
Any help would be appreciated. Also, I dont have a washer between the MK hub mounting bracket and the caliper mounting bracket.
Thanks as ever for the help.
Mark
mr T
posted on 24/6/13 at 08:05 PM Reply With Quote
move it over with washers
tony
StrikerChris
posted on 24/6/13 at 08:42 PM Reply With Quote
Im not sure I'd be happy moving things on brakes about with washers to be honest.something isnt sat how its designed to work, and id not bodge brakes despite some rather agricultural fixes ive done to cars of my own in the past.cant help you with your problem im afraid tho.just my opinion, hope you find a solution.
Chris
Sloan85
posted on 24/6/13 at 08:49 PM Reply With Quote
Might be the perspective but the disc doesn't look parallel to the mk caliper bracket?
http://mkindygsxr.blogspot.co.uk
posted on 24/6/13 at 08:50 PM Reply With Quote
Shim it out --- ie use washers. normal engineering practice not a bodge.
corrado vr6
posted on 24/6/13 at 09:07 PM Reply With Quote
My front brakes needed spacers from memory
http://r1indy7.wordpress.com/
Norfolkluegojnr
Third vote on washers. Had to do similar previously.
theprisioner
posted on 24/6/13 at 09:32 PM Reply With Quote
Washers as long as it is a few mm is ok. The big issue is the pads must be parallel to the disk otherwise the brake effectiveness will be crap until the pads wear down, not a good idea.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
ReMan
posted on 24/6/13 at 10:07 PM Reply With Quote
Is this front or rear and which callipers/discs are these
No expert , but I remember from my build there are a choice of discs with different size/ offset
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Poorscousertommy
posted on 24/6/13 at 10:52 PM Reply With Quote
thanks folks, didn't fancy shimming myself for the same reason.
if it was only one side I'd be happier it was a build issue, but with it being both I figure its down to chassis tolerances - I can't see MK giving me the wrong bits???
I'll rebuild anyway, can't be more than an hours work, and if all else fails its going to be a washer job.
oh - and they are rears if that helps!
thanks again!
[Edited on 24/6/13 by Poorscousertommy]
benchmark51
posted on 25/6/13 at 07:23 AM Reply With Quote
The picture isn't too clear and not enough of them. I would say that the parts are incompatible. I would definitly NOT mess about with washers.
pmc_3
posted on 25/6/13 at 07:37 AM Reply With Quote
The disc looks too thick to me? even centralised i'm not sure you would get the pads in
Daddylonglegs
posted on 25/6/13 at 08:46 AM Reply With Quote
Wot ^^^^^ he said
posted on 25/6/13 at 11:46 AM Reply With Quote
Eh?
The disc thickness must be a close fit to the slot in calliper bracket -- if the calliper bracket fits over the disc with a minimum running clearance all is well.
The reason being that the gap between the calliper bracket and the disc must be close enough to prevent a pad completely worn down to the metal slipping between the calliper carrier and the disc ---- yes this actually happens in real life if the pad is down to the metal and disc are very badly worn.
The thickness of metal backing plate on a typical brake is no more than than 4mm, so to prevent the pad pooping out in the worst case scenario (worn disc & worn out pad) a 0.75mm to 1.5mm clearance on each side of a new disc is about right.
posted on 25/6/13 at 12:06 PM Reply With Quote
Chris
Somehow "designed" and kit car brakes are not concepts that go together very often. It is a collection of parts adapted to bolt together.
