<<  1    2    3    4    5  >>
New Topic New Reply
Author: Subject: MK Indy R Hayabusa Build
hkp57
posted on 8/2/14 at 07:07 AM Reply With Quote
Sneek Preview of the wheels
hkp57
posted on 11/3/14 at 06:00 PM Reply With Quote
Random Update pictures
A few little jobs done, so just some random pictures
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
CosKev3
posted on 16/3/14 at 03:41 PM Reply With Quote
Coming together
Pretty sure the front shocks will need fitting the correct way though, read on here they are not designed to be used upside down and it will knacker them?
hkp57
posted on 14/6/14 at 11:22 AM Reply With Quote
Its been a while without an Update
Reverse Gear and Tank sat in place
Engine Back Out and Radiator on.
Fleet
DCT
hkp57
posted on 14/6/14 at 11:29 AM Reply With Quote
Dry Sump Arrived
Nova Racing dry sump kit.
I just couldn't live with commiting so much money to a Busa engine then use a wet sump with a swinging pick up.
[Edited on 14/6/14 by hkp57]
Fleet
DCT
hkp57
posted on 14/6/14 at 11:31 AM Reply With Quote
Dry Fit of interior panels
Started to layout Dash panel and the transmission tunnel panels.
Fleet
DCT
CosKev3
posted on 14/6/14 at 06:42 PM Reply With Quote
Dash looks good, is it a MK one?
What are your plans to get through iva with clocks in middle?
hkp57
posted on 15/6/14 at 04:35 PM Reply With Quote
Everything is being sourced by Andy at the Scottish Kit Car Centre but I think it is an MK supply.
I didn't know there is an issue with clocks in the middle as I have seen a lot out there like that including Andy's own car.
Fleet
DCT
CosKev3
posted on 15/6/14 at 06:08 PM Reply With Quote
Unless they are being sunk back in the dash panel,looks like they might be?
The edges fail the radius test.
hkp57
posted on 15/6/14 at 06:53 PM Reply With Quote
See what you mean now, I thought you meant as they were in the centre was the issue for view.
Well for the radius Andy is sure it will be fine as in others he has built
Fleet
DCT
CosKev3
posted on 15/6/14 at 07:06 PM Reply With Quote
Must be a lenient tester he uses!Or he fits some sort of panel over the clocks for IVA test only?
As a m8 of mine has failed radius test on bike clock edges.
hkp57
posted on 29/8/14 at 07:25 AM Reply With Quote
Some progress made now, had a little setback with the wheels. They arrived from Image and the powder coating was poorly finished from very rough casting underneath and strange ripples and creases in the finish.
To be fair to Image wheels though, they arranged for them to be collected by their courier. They were re-finished in a few days and sent back. Great service but quality control should never have let them out of the building.
[img][/img]
Final assembly and wiring of the dash well on its way now.
[img][/img]
First Side panel offered up for fitting.
[img][/img]
Fleet
DCT
hkp57
posted on 29/8/14 at 11:23 AM Reply With Quote
Helmet ready for the first drive lol
[img][/img]
Fleet
DCT
marco
posted on 29/8/14 at 01:12 PM Reply With Quote
I recognize the dash clocks I had fun setting them up. You won't have the Suzuki FI/Eobd warnings any more with those by the way. So if a sensor or something goes you'll have no warning.
[/URL]
[Edited on 29/8/14 by marco]
hkp57
posted on 29/8/14 at 01:17 PM Reply With Quote
The original engine harness still has all the conections in place, time to time I will hook up the original clocks and check for fault codes.
Well thats the plan anyway.
Fleet
DCT
marco
posted on 29/8/14 at 01:28 PM Reply With Quote
Good idea, let me know if you get stuck with the koso
beaver34
posted on 7/9/14 at 09:58 PM Reply With Quote
[img][/img]
Looks great, how much and where from?
hkp57
posted on 8/9/14 at 11:48 AM Reply With Quote
Paul Dalloway of GRAF-X CUSTOM PAINT did it for me, it also has more art work on the back. Paul does an amazing job and the finish is perfect, price really depends on the base helmet you choose and Simpson being the higher end at 650.
Check out his web site for offers - http://www.graf-x.co.uk/
Here is the back
Fleet
DCT
Dopdog
posted on 8/9/14 at 03:28 PM Reply With Quote
So how will you adjust the front shocks?
Minicooper
posted on 8/9/14 at 05:28 PM Reply With Quote
Take the bonnet off and adjust them, am I missing something?
Dopdog
posted on 8/9/14 at 05:40 PM Reply With Quote
Should have been a bit clearer, did you end up leaving the shocks upside down and was this OK or did you swap them over?
hkp57
posted on 8/9/14 at 08:24 PM Reply With Quote
I left them upside down but as you see its not rolling yet, this seems to be a topic thats been around a lot so I just copied how MK put their own cars together as seen on their Facebook page.
I think its been covered on this site also where Pro-tech also say its fine like this.
MK Sportscars
Fleet
DCT
hkp57
posted on 24/9/14 at 07:06 AM Reply With Quote
Little bit more progress
Side panels on, Front suspension back on and electrical system powered up.
[img][/img]
[img][/img]
[Edited on 24/9/14 by hkp57]
Fleet
DCT
mk85
posted on 24/9/14 at 07:12 AM Reply With Quote
Are you he side panels mk ones
hkp57
posted on 24/9/14 at 08:51 AM Reply With Quote
Yes Supplied through MK
Fleet
DCT
<<  1    2    3    4    5  >>
New Topic New Reply
