Author: Subject: 2.0 Blacktop Locost Almost Complete Project For Sale
speedstar
posted on 6/7/13 at 05:08 PM Reply With Quote
We started this project with the very best intentions of going racing, but with job changes and other unforseen issues, we are having to sell.
We have pretty much everything needed to build a working car, with a few trick parts.
Stuart Taylor Chassis (2x minor repairs, done properly with sleeve inserts); all painted and treated. Has been jigged and proven to be straight and true.
2 sets of front wishbones (1 standard, 1 race). Brackets need to be welded on (these are included)
Full set up at the rear (trailling arms) – no issues
Full set of stainless steel nuts, bolts and washers for the suspension arms
Steering rack + column
Front hubs
Rear axle (with brake disc conversion kit; no discs or callipers)
Full set of body mouldings, unpainted. We have double of some of the panels)
Aluminium side panels with folded edges
Type 9 with hydraulics clutch conversion and shifter relocation kit (moves the gear leaver back to a much more natural place for the driver
Pedal box
Brake bias bar
2x Brake master cylinders (and possibly one for the clutch)
Fuel tank - TIG welded and pressure tested
Fuel line + fuel filter
Stainless steel Fuel swirl pot
Brake line (including braided hoses and pressure switch for lights)
Handbrake + cables
2.0 Zetec Blacktop – reconditioned bottom end: new shells and ARP strengthened big end bolts, new piston rings, new oil seals, new gaskets. Head needs rebuilding but no known issues with it.
Shortened sump
Fabricated Engine Mounts
Ford ST inlet manifold for use with...
... GSXR Throttle bodies (includes silicone hose connectors)
Exhaust back box
Odds and ends – dash board dials, various warning lights, some tail lights, spot head lights, wiring, loads of nuts and bolts
Most things are photographed in the album linked below. Everything in the photos is included pretty much (except the engine crane!)
http://s864.photobucket.com/user/speedstar0610/slideshow/Locost%20Parts
Any questions drop me a PM. Collection from Hillingdon, Northwest London[b/].
Looking for a quick sale so all this for £3500
[Edited on 6/7/13 by speedstar]
speedstar
posted on 28/7/13 at 12:47 PM Reply With Quote
Bump
Any offers?
speedstar
posted on 1/8/13 at 02:01 PM Reply With Quote
bum again.
Open to offers guys
Spread the word.
speedstar
posted on 9/9/13 at 11:42 AM Reply With Quote
Ba-Doing...
Will take £2800.
If ther larger parts are wanted, might consider splitting.
